Download shows 'Progress' but nothing happens
Hi all, I am new to UIFlow and M5 Stack, I have done the Firmware flash using the M5Burner. Now using UIFlow, I can connect to the Serial Port, I can see the device sending default messages, then I press on Download, it shows 'Progress' but nothing happens. Can anyone please help?
I have tried the Download button on the right bottom of the UIFlow, this then shows Device Disconnected, but the webpage shows USB connected? -
@nak750 Have you installed the USB driver?
What OS are you using?
What port are you trying to write to? -
@ajb2k3 Thanks, Yes, I have installed the USB driver, I am using Windows 11. I have just managed to get it to work, it was the WiFi connection details. It looks like the programming is done OTA only.
