    earth sensor module - looking for an example for digital reading
    Modules
    earth sensor
    • H
      herb
      Hello, the earth sensor has an digital and an analog output pin. All examples are focused on analog reading.
      Can someone provide an example for digital reading?
      teastainT ajb2k3A 2 Replies Last reply Reply Quote 0
      • teastainT
        teastain @herb
        @herb Here you go:
        https://github.com/m5stack/M5Stack/blob/master/examples/Unit/EARTH/EARTH.ino
        Both analog and digital.
        The earth sensor is rather...'simple'
        from the docs page
        https://docs.m5stack.com/en/unit/earth
        you can see that the 'Ain' just reads the voltage across the sensor and the 'Din' is at least the threshold comparator, adjusted by the trim pot on back.
          ajb2k3 @herb
          @herb What are you hoping to achieve as Digital rating only provides a 1 or 0.
          the only way to get values is through analogue and there is a project in the project zone of uiflow 2 found here https://uiflow2.m5stack.com/?pkey=3dd144a31f32480e9a7ed95461a9107a
