    External Antenna Questsion
    M5 Stick/StickC
    5
    4.1k
      stevedee78
      Has anyone already soldered an external antenna to the M5stickC or plus? If so, where can I find information about it?
        As far as I am aware no one has done it. You need to buy an external signal booster to increase the wifi range.
          stevedee78
          I have See pics with external Antenna.
          • teastainT
            teastain @stevedee78
            @stevedee78 I see you are intending to plague other people with the Marauder app.
            Pentesting your own network would not require a longer range, afforded by the external antenna.
            It is astounding to me that so many people are purchasing M5StickC to run Nemo and Marauder, and deauth apps.
            • D
              Davy-J @teastain
              @teastain Thankfully only 2.4GHz is possible with the M5 Stick ! I've found it a useful tool to forewarn of the dangers posed by signing on to a cloned portal via Google. No-one on this forum would do that ; our less-aware Great Uncle Tarquin might...
