    AtomDTU NB-IoT
    32 Posts 2 Posters 39.0k Views
      Felix22
      now, i have a new problem.
      The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
      I see no difference...
      The orange part is working and the tree other is not working
      • Domainname
      • IP-Address
      • Dyndns
        not working...
        test.mosquitto.org is working fine.
        Hello @Felix22
        hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
          Felix22
          you mean the blocks at "Fortgeschritten" / MQTT ?
          over there it connects over Wlan/Wifi...
          Is there a MQTT-Block how i can say the RX and TX pin ?
            Hello @Felix22
            no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
              Felix22
              this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
              But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
              Do you also use the Atom DTU NB-IoT ?
                Hello @Felix22
                not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                  Hello @Felix22
                  I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                    Felix22
                    Do you have a list with the Status Codes ?
                    Signal Qualität: 16
                    MQTT-Connection: 0
                    Network-Registration: 7
                    GPRS network registration
                      Hello @Felix22
                      sure, here you are:
                      • Signal Quality: 17
                      • MQTT-Connection: 0
                      • Network Registration: 7
                      • GPRS Network Registration: 5
                      and when connected to MQTT broker
                      • MQTT-Connection: 1
                        Felix22
                        Hello Felix
                        By the error code I meant what the individual numbers mean.
                        Each code 0 to x
                        Do you have a code list ?
                        Greeting
                          Hello @Felix22
                          no, sorry, I don't have such a list. But if the error code is from an AT command you should be able to find its meaning from the AT command document linked on the product page.
