    AtomDTU NB-IoT
    32 Posts 2 Posters 39.0k Views
      Hello @Felix22
      hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
        Felix22
        you mean the blocks at "Fortgeschritten" / MQTT ?
        over there it connects over Wlan/Wifi...
        Is there a MQTT-Block how i can say the RX and TX pin ?
          Hello @Felix22
          no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
            Felix22
            this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
            But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
            Do you also use the Atom DTU NB-IoT ?
              Hello @Felix22
              not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
              And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                Hello @Felix22
                I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                  Felix22
                  Do you have a list with the Status Codes ?
                  Signal Qualität: 16
                  MQTT-Connection: 0
                  Network-Registration: 7
                  GPRS network registration
                    Hello @Felix22
                    sure, here you are:
                    • Signal Quality: 17
                    • MQTT-Connection: 0
                    • Network Registration: 7
                    • GPRS Network Registration: 5
                    and when connected to MQTT broker
                    • MQTT-Connection: 1
                      Felix22
                      Hello Felix
                      By the error code I meant what the individual numbers mean.
                      Each code 0 to x
                      Do you have a code list ?
                      Greeting
                        Hello @Felix22
                        no, sorry, I don't have such a list. But if the error code is from an AT command you should be able to find its meaning from the AT command document linked on the product page.
