    AtomDTU NB-IoT
    32 Posts 2 Posters 36.3k Views
      Felix22
      Many thanks.
      I will write to the support from q.beyond.
      If the connection will go on. What are the Code for an MQTT connection ?
      If i become an IP-Address, can i use the "normal" MQTT Blockly ??
      Regards,
        Hello @Felix22
        please refer to the SIM7020 documentation for MQTT commands. You can find the PDFs here - section Related Link.
        As soon as the modem gets an IP address the last AT command AT+CGCONTRDP sent by Init NB-IoT DTU block should succeed and then you can use all the other MQTT blocks.
          Felix22
          a.beyond say, she works in Switzerland with Swisscom NB.
          How can I explicit connect to Swisscom (AT-Command) ?
            Hello @Felix22
            AT+COPS=1,2,"22801"
              Felix22
              b'AT+CSQ\r\r\n+CSQ: 18,0\r\n\r\nOK\r\n'
              men, i have a signal ?
              b'AT+CSTT="iotsim.melita.io","",""\r\r\nOK\r\n'
              b'AT+CSTT?\r\r\n+CSTT: "iotsim.melita.io","",""\r\n\r\nOK\r\n'
              APN is set correct ?
              b'AT+CGREG?\r\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
              Registered ?
              b'AT+COPS: 1,2,"22801"\r\r\nERROR\r\n'
              b'AT+COPS?\r\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
              b'AT+CGACT?\r\r\n+CGACT: 1,0\r\n\r\nOK\r\n'
              If i have a connection, do i become an ip-address ?
              with the command AT+CIFSR
                Hello @Felix22
                it is my understanding that AT+CIFSR returns the local IP address in a TCP or UDP connection. (It's an AT command for compatibility with SIM800.)
                See PDF document SIM7020 Series_TCPIP_Application Note_V1.04 - 6.2 TCP Client Connection. You'll find the link to the PDF here.
                The way I use to set the APN is described in the same TCP/IP PDF - 3.2 APN Manual Configuration.
                  Felix22
                  Result:
                  b'\r\nOK\r\n'
                  b'\r\nOK\r\n'
                  b'\r\nOK\r\n'
                  b'\r\nOK\r\n'
                  b'\r\nOK\r\n\r\n+CPIN: READY\r\n'
                  b'\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
                  b'\r\n+CGCONTRDP: 1,5,"iotsim.melita.io","10.xx.xx.xx.255.255.255.0",,"212.xx.xx.xx","212.xx.xx.xx",,,,,1500\r\n\r\nOK\r\n'
                  Im a big step wider... now, i have become my ip address... :-)
                  Now i think... MQTT, next step.
                    Felix22
                    Juhuuuu !!
                    It works !
                    More Information and the solution will follow...
                    @felmue : many thanks
                      Hello @Felix22
                      I am happy to hear you got it working.
                        Felix22
                        now, i have a new problem.
                        The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
                        I see no difference...
                        The orange part is working and the tree other is not working
                        • Domainname
                        • IP-Address
                        • Dyndns
                          not working...
                          test.mosquitto.org is working fine.
                          Hello @Felix22
                          hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
                            Felix22
                            you mean the blocks at "Fortgeschritten" / MQTT ?
                            over there it connects over Wlan/Wifi...
                            Is there a MQTT-Block how i can say the RX and TX pin ?
                              Hello @Felix22
                              no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
                                Felix22
                                this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
                                But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
                                Do you also use the Atom DTU NB-IoT ?
                                  Hello @Felix22
                                  not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                                  And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                                    Hello @Felix22
                                    I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                                      Felix22
                                      Do you have a list with the Status Codes ?
                                      Signal Qualität: 16
                                      MQTT-Connection: 0
                                      Network-Registration: 7
                                      GPRS network registration
                                        Hello @Felix22
                                        sure, here you are:
                                        • Signal Quality: 17
                                        • MQTT-Connection: 0
                                        • Network Registration: 7
                                        • GPRS Network Registration: 5
                                        and when connected to MQTT broker
                                        • MQTT-Connection: 1
                                          Felix22
                                          Hello Felix
                                          By the error code I meant what the individual numbers mean.
                                          Each code 0 to x
                                          Do you have a code list ?
                                          Greeting
                                            Hello @Felix22
                                            no, sorry, I don't have such a list. But if the error code is from an AT command you should be able to find its meaning from the AT command document linked on the product page.
