    m5stack cardputer doesn't turn on.
    26 Posts 10 Posters 32.1k Views
      Hello @ajb2k3
      just to clarify: the M5StampS3 (used in M5Cardputer) doesn't have an CH9120. The ESP32S3 has USB built-in using GPIO19/20. But it is correct that the built-in USB exposes multiple ports and functionalities. See here.
        I read that the internal adapter (on die) is based on the CH9120 chip (hence the need for the driver)
        Thanks for the pointer as it did show the issue 0_1706954335417_Screenshot 2024-02-03 at 09.58.11.png
        During default Programming mode the S3's go into Serial JTAG/OTG mode which blocks the Serial port with firmwares but the button press override and drops it into SPI mode.
        It would appear that these firmwares are blocking the SPI mode access.
        @felmue @teastain can you test the pins to see what they are doing when running these firmwares?
        • teastainT Offline
          teastain @ajb2k3
          @ajb2k3 Adam, very interesting. I will look into it.
          My first S3 was the LilyGO T-Display S3, which took several weeks and the feeling that I had 'bricked' it by fumbling around. YouTuber Volos gave me insights to rein - in control.
          I now have a LilyGO T-Display S3 AMOLED, extremely high resolution and clarity and and a large screen T-HMI, very well engineered, but not enough bit resolution for such a large screen.
            Hello @ajb2k3
            using M5Burner I've downloaded the below firmware to my M5Cardputer. Then measured G0, G1, G2 and G46 while the firmware was running.
               NEMO for  | Marauder for | Cardputer | Volos Cardputer
               Cardputer | Cardputer    | User Demo | TV Remote
               v2.4.1    | v0.13.6      | v0.9.1    | v1.0
            G0   3.3 V   |  3.3 V       |  3.3 V    |  3.3 V
            G1   3.3 V   |  3.3 V       |  3.3 V    |  3.3 V
            G2   3.3 V   |  3.3 V       |  3.3 V    |  3.3 V
            G46  3.3 V   |  0 V         |  0 V      |  3.3 V
            Note: Downloading firmware from M5Burner always put the M5StampS3 into download mode automatically - at no point did I have to manually set it to download mode using G0 button.
            Note: I am on Ubuntu 20.04
            teastainT Sl4sh00S 2 Replies Last reply Reply Quote 0
              ajb2k3 @teastain
              @teastain I thought you was Volos for a while
              @felmue Thanks, It looks like that Serial/JTAG is the default mode unless USB OTG is set.
              Thats what I though, Nemo and Marauda are pulling G0 high
              • teastainT Offline
                teastain @felmue
                @felmue You are thorough.
                • Sl4sh00S Offline
                  Sl4sh00 @felmue
                  @felmue said in m5stack cardputer doesn't turn on.:
                  Hello @ajb2k3
                  Is there any way I can reset it so it turns back on?
                  • teastainT Offline
                    teastain @Sl4sh00
                    @sl4sh00 Yes.
                    What app did you try to install?
                    That could be the root of the problem.
                    The BootLoader firmware is unbreakable, so there is no real problem.
                    Sl4sh00S 1 Reply Last reply Reply Quote 0
                    • robskiR Offline
                      robski
                      @Sl4sh00 can you try this...press and hold boot button (on side of cardputer or top of stamp) while holding connect usb then let button go, then try to load fresh firmware in M5Burner.
                      • Sl4sh00S Offline
                        Sl4sh00 @teastain
                        @teastain marauder
                        • Sl4sh00S Offline
                          Sl4sh00 @robski
                          @robski I tried holding down the reset button but nothing happened, is there any other way to install the firmware?
                          • teastainT Offline
                            teastain @Sl4sh00
                            @sl4sh00 To put it into 'download' mode you can do as @robski suggested or:
                            Press and hold the G0 Boot button...while holding it in, press and release the reset button, THEN release the G0 Boot.
                            While doing this you can check the connection status in whatever burner app you are using.
                            Please tell us if you can see the connection status AT ALL, this would be helpful in solving your problem.
                            Sl4sh00S T D 3 Replies Last reply Reply Quote 2
                            • Sl4sh00S Offline
                              Sl4sh00 @teastain
                              @teastain Thank you my brother, it works just like you said. Now it works again.
                              • teastainT Offline
                                teastain @Sl4sh00
                                @sl4sh00 Thank you for getting back to us!
                                • W Offline
                                  willyam @teastain
                                  @teastain bro thank u so mutch i tried it the whole day but nothing helped thank u so mutch , God bless you
                                    twinturbo @teastain
                                    @teastain i tried the same for my cardputer but no luck
                                    • G Offline
                                      gera5034 @Sl4sh00
                                      @sl4sh00 said in m5stack cardputer doesn't turn on.:
                                      m5stack cardputer doesn't turn on, after I connected it to the computer and tried to put an app on the M5Burner and it didn't turn on anymore and when I plug it into the computer it keeps connecting and
                                      Comprei um cardputer para mim, quero saber como faço para instalar as aplicações do git hub, e só baixar e passar para o cartão sd .
                                      • Sl4sh00S Offline
                                        Sl4sh00 @gera5034
                                        @gera5034 baixa o M5Burner no site da M5. nele vc põe a opção do cardputer e aparece os apps q funcionam nele.
                                          daft1 @teastain
                                          @teastain
                                          hello just wondering is the screen going to be off the entire while doing this? and im wondering how do i reset the firmware with it bricked and the screen off? ive consitently tried the button thing and plugging in at same time, maybe not getting it right idk.
                                          im on linux (chromebook) and i got the burner unzipped loaded up and i couldnt get the cardputer to go onto the os files system i could only find it through port and in the linux usb sharing.
                                          so i instead tried to download the firmware onto the local machine and then to the device in thw port and then it turned off when i did it. did i add one firmware o to the other making it brick or crash or just sent to cardputer bad?
