    Cardputer COM Not Working
    87 Posts 20 Posters 200.0k Views 3 Watching
      ajb2k3 @HankTTTop
      @hanktttop Just updated my comment
        HankTTTop @ajb2k3
        @ajb2k3 It is OFF. However, it still starts the moment the cable is connected. Even with the switch turned off.
          ajb2k3 @HankTTTop
          @hanktttop It takes a bit of practice but on a Mac it should appear as a USB Modem if timed properly. It is difficult to do.
            Hello @ajb2k3
            my apologies - I only read the comment of the M5Cardputer documentation w/o trying it myself.
              HankTTTop @ajb2k3
              @ajb2k3 Nothing yet. Apparently it behaves as if it were connected to a charger, not a computer. I reinstalled all the drivers, restarted the machine, but it's still the same. And I don't know if it's normal behavior for it to turn on as soon as it's connected, even with the switch turned OFF.
                Hello guys
                @ajb2k3 : hmm, I've just double-checked with my M5Cardputer following your video and the LED does not light up. Maybe it depends on what firmware it currently runs?
                @HankTTTop : yes, that is normal behaviour - at least my M5Cardputer does that as well - it starts up as soon as USB is connected - even when off. (It is my understanding that the ON/OFF switch is for the battery only.)
                BTW: have you tried a different USB cable?
                H 1 Reply Last reply Reply Quote 2
                  HankTTTop @felmue
                  @felmue I tried different USB ports, but now that you mention it, it could be the problem. I'm using a USB-C that came from a portable console, which doesn't allow data transfer over this connection.
                  I'll see if I can get another one tomorrow when the local businesses are open. Thanks for the sugestion.
                    HankTTTop
                    New cable, same error. In fact, I just tested it on Fedora 39 (fresh installed), I still haven't been able to put the device in download mode. Maybe I'm forgetting a drive, which makes the device "recognize" the computer as a charger. Still, I reinstalled them all again, with no result.
                      OK next step is to VERY Gently pull the Stamp form the card keyboard (the pins are tiny) then with it removed you need to open M5Burner (after a fresh reboot of the computer) hold the button down hidden under the label, connect a USB cable in and wait for the led to turn green. I'm just digging out my old windows computer to make a video.
                      And M5Burner should report as a USB Modem.
                      • robskiR Offline
                        robski @HankTTTop
                        I have M5Dial with StampS3 at the back...had to remove sticker to see and feel when "boot" button is pressed and hold before usb is plugged in - its almost hard to sense way different from pressing reset button where you can hear click.
                        With my Dial when say com13 was unresponsive then going in to boot mode made com12 to be available so in short words diff com for programming and different for boot mode - thats my experience with StampS3 from my M5Dial - i had it few times in some unresponsive mode.
                          ajb2k3 @robski
                          @robski I tried my old computer but forgot windows was soo slow compared to a Mac so need to wait to pay day to buy a new windows mini pc.
                            HankTTTop
                            I also tried this button, here is another video: https://www.youtube.com/watch?v=Vlx79AmbrPk
                            I have tried all the solutions so far: Pressing the BTNGO key, pressing the button below the sticker, no sign of the LED or recognition on the machine, whether in M5 Burner or in the device manager. I'm trying to contact M5 Stack support to check the possibility of a hardware problem.
                            • robskiR Offline
                              robski
                              have you tried Uiflow2 web burner option with "boot press"? bottom left corner
                              (![0_1706622355894_uiflowburner.jpg](Uploading 100%) image url)
                                HankTTTop
                                I didn't know about this application. I just tested it, but it doesn't connect either.
                                • robskiR Offline
                                  robski @HankTTTop
                                  you said that com5 is showing and vanishing when you connect to usb,
                                  what com port is showing when you press and hold BTN Download Mode button and then connect usb? Is it com5 too or different com number?
                                    HankTTTop
                                    Only the same COM3 as before appears, but with the description "Paired". But you can't initiate communication. There are no other USB devices connected to the machine.
                                      Have you installed both the cdc and serial driver?
                                        HankTTTop @ajb2k3
                                        @ajb2k3 Maybe not. Following the guide, I installed this FTDI driver. The page says that the Windows installer will install both the VCP and D2xx: https://ftdichip.com/drivers/vcp-drivers/
                                        Have I been installing the wrong driver this whole time? facepalm
                                        • teastainT Offline
                                          teastain @HankTTTop
                                          @hanktttop Seeing that this is a "Flipper" type hacking tool...maybe it attacked you and is deauthering you.
                                          TV B-Gone port (thanks to MrArm's HAKRWATCH) to shut off many infrared-controlled TVs, projectors and other devices
                                          AppleJuice iOS Bluetooth device pairing spam
                                          Bluetooth device notification spamming for SwiftPair (Windows) and Android
                                          WiFi Spam - Funny SSIDs, WiFi Rickrolling, and a Random mode that creates hundreds of randomly-named SSIDs per minute
                                          WiFi NEMO Portal - A captive portal that tries to social engineer email credentials - saves usernames and passwords to SD Card (if inserted into a supported reader)
                                          WiFi SSID Scanner - Display 2.4 GHz SSIDs nearby, get information about them, and even clone the SSIDs in NEMO Portal
                                            HankTTTop @teastain
                                            @teastain Yes, it is. I work in information security, so I want to install it to do some tests, nothing to attack other people. I don't believe it attacked the device, at no point was the binary executed or installed on the cardputer yet. In fact, the project is open source and you can check it here: https://github.com/n0xa/m5stick-nemo/
