    Can't register devices to an account
    14 Posts 3 Posters 14.1k Views 1 Watching
      ciconde
      @ajb2k3 Register process is done with M5 Burner, isn't it?
        ajb2k3 @ciconde
        @ciconde yes when you erase and burn new firmware to the controller
          ciconde
          @ajb2k3 Just did exactly that: first erase, then burned the firmware.
          M5Burner was logged in, but no dialog to bind the device:
          Why there's no option nor dialog to bind? I'm using M5Burner latest version, just downloaded it...
          I'd like to suggest a bind button on the UI to bind a successfully connected device, so this process would be even better.
          Thanks!
            Are you sure that you are burning UIFlow2 and not UIFlow?
            UIFlow has a manual connection method.
            https://studio.youtube.com/video/2K4hHGtskAU/edit
              ciconde
              No, being regular M5stack Core2 and regular Atom Lite they are not S3 and therefore I can't burn UIFlow2. Am I wrong?
              I can't recall the manual binding method for UIFlow, would you be so kind of clarifying this?
              Long time ago, when I burnt my old devices the burner would ask me if I wanted to bind.
              This is the only procedure I know.
                mtylerjr
                Core2 is one of the few (only?) platforms you can use with either, at the moment.
                I know this because I burned Uiflow2 and Uiflow1 both, on my Core2 AWS, last Friday.
                Uiflow1 is more complete at the moment, so that is what I am using for the next couple of weeks at least, until more stuff is added to Uiflow2, which is still in Alpha.
                  ajb2k3 @ciconde
                  @ciconde UIFlow 1 devices show an api code on the screen which has to be typed into UIFlow manually. UIFlow 2 devices don’t show this code and requests to bind during the firmware burning process
                    ciconde
                    UIFlow 1 devices formerly had a way to add them to my user.
                    Not only they show in my Device Manager, they also refuse to be downloaded anonymously, which is great.
                    I don't find how to do it anymore.
                    Please mind all this issue is around binding a device to an user, not how to bind them to the programming tool, which is OK with API KEY.
                      ciconde
                      @ajb2k3 Any comments on how to add my devices to this "M5Stack Device Platform - Beta"?
                        ajb2k3 @ciconde
                        @ciconde said in Can't register devices to an account:
                        UIFl0w2?
                        You need to log into M5Burner with your forum details and when you erase and burn UIFLOW2 firmware you will be asked to register device to your account
