    Can't register devices to an account
    14 Posts 3 Posters 14.8k Views 1 Watching
      ciconde
      Also just happened with Atom Lite, also V1.12.2
        ciconde
        @ajb2k3 Register process is done with M5 Burner, isn't it?
          ajb2k3 @ciconde
          @ciconde yes when you erase and burn new firmware to the controller
            ciconde
            @ajb2k3 Just did exactly that: first erase, then burned the firmware.
            M5Burner was logged in, but no dialog to bind the device:
            Why there's no option nor dialog to bind? I'm using M5Burner latest version, just downloaded it...
            I'd like to suggest a bind button on the UI to bind a successfully connected device, so this process would be even better.
            Thanks!
              Are you sure that you are burning UIFlow2 and not UIFlow?
              UIFlow has a manual connection method.
              https://studio.youtube.com/video/2K4hHGtskAU/edit
                ciconde
                No, being regular M5stack Core2 and regular Atom Lite they are not S3 and therefore I can't burn UIFlow2. Am I wrong?
                I can't recall the manual binding method for UIFlow, would you be so kind of clarifying this?
                Long time ago, when I burnt my old devices the burner would ask me if I wanted to bind.
                This is the only procedure I know.
                  mtylerjr
                  Core2 is one of the few (only?) platforms you can use with either, at the moment.
                  I know this because I burned Uiflow2 and Uiflow1 both, on my Core2 AWS, last Friday.
                  Uiflow1 is more complete at the moment, so that is what I am using for the next couple of weeks at least, until more stuff is added to Uiflow2, which is still in Alpha.
                    ajb2k3 @ciconde
                    @ciconde UIFlow 1 devices show an api code on the screen which has to be typed into UIFlow manually. UIFlow 2 devices don’t show this code and requests to bind during the firmware burning process
                      ciconde
                      UIFlow 1 devices formerly had a way to add them to my user.
                      Not only they show in my Device Manager, they also refuse to be downloaded anonymously, which is great.
                      I don't find how to do it anymore.
                      Please mind all this issue is around binding a device to an user, not how to bind them to the programming tool, which is OK with API KEY.
                        ciconde
                        @ajb2k3 Any comments on how to add my devices to this "M5Stack Device Platform - Beta"?
                          ajb2k3 @ciconde
                          @ciconde said in Can't register devices to an account:
                          UIFl0w2?
                          You need to log into M5Burner with your forum details and when you erase and burn UIFLOW2 firmware you will be asked to register device to your account
