    Can't register devices to an account
    14 Posts 3 Posters 13.9k Views 1 Watching
      ciconde
      Core2 V1.12.2
        ciconde
        Also just happened with Atom Lite, also V1.12.2
          ciconde
          @ajb2k3 Register process is done with M5 Burner, isn't it?
            ajb2k3 @ciconde
            @ciconde yes when you erase and burn new firmware to the controller
              ciconde
              @ajb2k3 Just did exactly that: first erase, then burned the firmware.
              M5Burner was logged in, but no dialog to bind the device:
              Why there's no option nor dialog to bind? I'm using M5Burner latest version, just downloaded it...
              I'd like to suggest a bind button on the UI to bind a successfully connected device, so this process would be even better.
              Thanks!
                Are you sure that you are burning UIFlow2 and not UIFlow?
                UIFlow has a manual connection method.
                https://studio.youtube.com/video/2K4hHGtskAU/edit
                  ciconde
                  No, being regular M5stack Core2 and regular Atom Lite they are not S3 and therefore I can't burn UIFlow2. Am I wrong?
                  I can't recall the manual binding method for UIFlow, would you be so kind of clarifying this?
                  Long time ago, when I burnt my old devices the burner would ask me if I wanted to bind.
                  This is the only procedure I know.
                    mtylerjr
                    Core2 is one of the few (only?) platforms you can use with either, at the moment.
                    I know this because I burned Uiflow2 and Uiflow1 both, on my Core2 AWS, last Friday.
                    Uiflow1 is more complete at the moment, so that is what I am using for the next couple of weeks at least, until more stuff is added to Uiflow2, which is still in Alpha.
                      ajb2k3 @ciconde
                      @ciconde UIFlow 1 devices show an api code on the screen which has to be typed into UIFlow manually. UIFlow 2 devices don’t show this code and requests to bind during the firmware burning process
                        ciconde
                        UIFlow 1 devices formerly had a way to add them to my user.
                        Not only they show in my Device Manager, they also refuse to be downloaded anonymously, which is great.
                        I don't find how to do it anymore.
                        Please mind all this issue is around binding a device to an user, not how to bind them to the programming tool, which is OK with API KEY.
                          ciconde
                          @ajb2k3 Any comments on how to add my devices to this "M5Stack Device Platform - Beta"?
                            ajb2k3 @ciconde
                            @ciconde said in Can't register devices to an account:
                            UIFl0w2?
                            You need to log into M5Burner with your forum details and when you erase and burn UIFLOW2 firmware you will be asked to register device to your account
