    [SOLVED] arduino save int variable value on SD
    11
    31.5k
    • C
      cepics
      Hi, how can I save an int variable value on m5stack? (like eeprom)
      is it possible to save it on sd card?
      tnks
      • lukasmaximusL
        I'm not sure I quite understand your question. Do you want to log the output of a variable to a text file on the SD?
        • C
          cepics
          on esp8266, to save/read a value in to eeprom, I do:
          #include <EEPROM.h>
          int address = 0;
           EEPROM.begin(512);
          byte x = sonar.convert_cm(echoTime);
            delay(1000);
            EEPROM.write(address, x);
            delay(1000);
            EEPROM.commit();
            delay(1000);
            x = EEPROM.read(address);
            delay (500);
          how can I do to save/read x variable on sd with m5?
          tnks a lot
          • RopR
            Rop
            M5Stack has the same "EEPROM" (Which is really a simulation that simply uses a small partition in the flash memory.) If I am not mistaken the code you quote should work still on the ESP32 (and thus on the M5Stack).
            ESP32's have something called NVM, which stores key-value pairs in another partition of the same flash. In the Arduino world, "Preferences.h" provides a wrapper to use these functions. Have a look here for an example that stores a value (the number of times the ESP was booted) in flash.
            • yelloweliseY
              yellowelise
              How many cycle before dead of flash partition?
              • C
                cepics
                I would like to save some variables, like I did with EEPROM on esp8266, but on M5Stack sd.. (to kill sd card instead of esp32 memory)
                I'm trying this sketch:
                // http://forum.m5stack.com/topic/184/problems-writing-to-sd-card
                #include <M5Stack.h>
                //Micro SD / TF Card Test
                String cal;
                String lum;
                String unit;
                bool brght = 0;
                bool ftmt = 1;
                int x = 1680;
                void listDir(fs::FS &fs, const char * dirname, uint8_t levels) {
                  // Print blank line on screen
                  M5.Lcd.printf(" \n  ");
                  Serial.printf("Listing directory: %s\n", dirname);
                  M5.Lcd.printf("Listing directory: %s\n", dirname);
                  File root = fs.open(dirname);
                  if (!root) {
                    Serial.println("Failed to open directory");
                    M5.Lcd.println("Failed to open directory");
                    return;
                  if (!root.isDirectory()) {
                    Serial.println("Not a directory");
                    M5.Lcd.println("Not a directory");
                    return;
                  File file = root.openNextFile();
                  while (file) {
                    if (file.isDirectory()) {
                      Serial.print("  DIR : ");
                      M5.Lcd.print("  DIR : ");
                      Serial.println(file.name());
                      M5.Lcd.println(file.name());
                      if (levels) {
                        listDir(fs, file.name(), levels - 1);
                    } else {
                      Serial.print("  FILE: ");
                      M5.Lcd.print("  FILE: ");
                      Serial.print(file.name());
                      M5.Lcd.print(file.name());
                      Serial.print("  SIZE: ");
                      M5.Lcd.print("  SIZE: ");
                      Serial.println(file.size());
                      M5.Lcd.println(file.size());
                void readFile(fs::FS &fs, const char * path) {
                  Serial.printf("Reading file: %s\n", path);
                  M5.Lcd.printf("Reading file: %s\n", path);
                  File file = fs.open(path);
                  if (!file) {
                    Serial.println("Failed to open file for reading");
                    M5.Lcd.println("Failed to open file for reading");
                    return;
                  Serial.print("Read from file: ");
                  M5.Lcd.print("Read from file: ");
                  while (file.available()) {
                    int ch = file.read();
                    Serial.write(ch);
                    M5.Lcd.write(ch);
                void writeFile(fs::FS &fs, const char * path, const char * message) {
                  Serial.printf("Writing file: %s\n", path);
                  M5.Lcd.printf("Writing file: %s\n", path);
                  File file = fs.open(path, FILE_WRITE);
                  if (!file) {
                    Serial.println("Failed to open file for writing");
                    M5.Lcd.println("Failed to open file for writing");
                    return;
                  if (file.print(message)) {
                    Serial.println("File written");
                    M5.Lcd.println("File written");
                  } else {
                    Serial.println("Write failed");
                    M5.Lcd.println("Write failed");
                  Wire.begin();
                  Serial.begin(115200);
                  // Lcd display
                  M5.Lcd.setBrightness(100);
                  M5.Lcd.fillScreen(BLACK);
                  M5.Lcd.setCursor(0, 10);
                  M5.Lcd.setTextColor(WHITE);
                  M5.Lcd.setTextSize(2);
                  // Page Header
                  M5.Lcd.setCursor(0, 05);
                  M5.Lcd.printf("Testing SD Card Functions:\r\n");
                  cal = String("cal = ") + String(x) + "\r\n";
                  lum = String("lum = ") + String(brght) + "\r\n";
                  unit = String("unit = ") + String(ftmt) + "\r\n";
                  writeFile(SD, "/cal.txt", cal.c_str()); // questa funziona!!!!
                  writeFile(SD, "/lum.txt", lum.c_str()); // questa funziona!!!!
                  writeFile(SD, "/unit.txt", unit.c_str()); // questa funziona!!!!
                  M5.Lcd.printf("");
                  readFile(SD, "/cal.txt");
                  readFile(SD, "/lum.txt");
                  readFile(SD, "/unit.txt");
                  // put your main code here, to run repeatedly:
                  M5.update();
                but I can't understand how to read from sd and use the variables in the sketch..
                I need to read and write two boolean state and one int variables ..
                I'm a newbi and all the sketch I found on line that use sd.h library doesn't work on M5Stack
                if I upload read/write arduino sd example, this is the serial monitor output:
                error opening test.txt
                please help
                thanks a lot
                • C
                  cepics @yellowelise
                  @yellowelise said in arduino save int variable value:
                  I'm interested too
                    ajb2k3 @cepics
                    @cepics
                    Have you tried playing with the sd read and write examples?
                    • C
                      cepics @ajb2k3
                      @ajb2k3 said in arduino save int variable value:
                      @cepics
                      yes this one
                        SD card read/write
                       This example shows how to read and write data to and from an SD card file
                       The circuit:
                       * SD card attached to SPI bus as follows:
                       ** MOSI - pin 11
                       ** MISO - pin 12
                       ** CLK - pin 13
                       ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
                       created   Nov 2010
                       by David A. Mellis
                       modified 9 Apr 2012
                       by Tom Igoe
                       This example code is in the public domain.
                      #include <SPI.h>
                      #include <SD.h>
                      File myFile;
                        // Open serial communications and wait for port to open:
                        Serial.begin(9600);
                        while (!Serial) {
                          ; // wait for serial port to connect. Needed for native USB port only
                        Serial.print("Initializing SD card...");
                        if (!SD.begin(4)) {
                          Serial.println("initialization failed!");
                          while (1);
                        Serial.println("initialization done.");
                        // open the file. note that only one file can be open at a time,
                        // so you have to close this one before opening another.
                        myFile = SD.open("test.txt", FILE_WRITE);
                        // if the file opened okay, write to it:
                        if (myFile) {
                          Serial.print("Writing to test.txt...");
                          myFile.println("testing 1, 2, 3.");
                          // close the file:
                          myFile.close();
                          Serial.println("done.");
                        } else {
                          // if the file didn't open, print an error:
                          Serial.println("error opening test.txt");
                        // re-open the file for reading:
                        myFile = SD.open("test.txt");
                        if (myFile) {
                          Serial.println("test.txt:");
                          // read from the file until there's nothing else in it:
                          while (myFile.available()) {
                            Serial.write(myFile.read());
                          // close the file:
                          myFile.close();
                        } else {
                        // nothing happens after setup
                      it compile but the serial monitor say:
                      right now, with an example from here, I can write an int variable in a file on sd
                      int cal = 2000;
                        Wire.begin();
                        File file = SD.open("/cal.txt", FILE_WRITE);
                        if (!file) {
                          return;
                        if (file.print(cal)) {
                        } else {
                      and I can read the file with
                      int ch;
                        Wire.begin();
                        File file = SD.open("/cal.txt");
                        if (!file) {
                          return;
                          ch = file.read();
                          Serial.write(ch);
                          M5.Lcd.write(ch);
                      but I can't use the "ch" variable ..
                      if I add, on the "read" sketch
                      int y = ch + 2000;
                      Serial.print(y);
                      in the serial monitor I have:
                      M5Stack initializing...O�������
                      Read from file: 2000
                      2048
                      2048 instead of 4000
                      now I'm searching how to convert ASCII to binary
                      thanks for interest..
                      • H
                        heybin
                        Hello,if you want use eeprom, suggest try this example in arduino ide:
                        file->Examples->Preferences
                        https://github.com/espressif/arduino-esp32/blob/master/libraries/Preferences/examples/StartCounter/StartCounter.ino
                        • C
                          cepics
                          the solution:
                          file.parseInt();
                          thanks a lot !!!
