    [SOLVED] arduino save int variable value on SD
    11 Posts 6 Posters 33.8k Views 2 Watching
      cepics
      Hi, how can I save an int variable value on m5stack? (like eeprom)
      is it possible to save it on sd card?
      tnks
      • lukasmaximusL Offline
        I'm not sure I quite understand your question. Do you want to log the output of a variable to a text file on the SD?
          cepics
          on esp8266, to save/read a value in to eeprom, I do:
          #include <EEPROM.h>
          int address = 0;
           EEPROM.begin(512);
          byte x = sonar.convert_cm(echoTime);
            delay(1000);
            EEPROM.write(address, x);
            delay(1000);
            EEPROM.commit();
            delay(1000);
            x = EEPROM.read(address);
            delay (500);
          how can I do to save/read x variable on sd with m5?
          tnks a lot
          • RopR Offline
            Rop
            M5Stack has the same "EEPROM" (Which is really a simulation that simply uses a small partition in the flash memory.) If I am not mistaken the code you quote should work still on the ESP32 (and thus on the M5Stack).
            ESP32's have something called NVM, which stores key-value pairs in another partition of the same flash. In the Arduino world, "Preferences.h" provides a wrapper to use these functions. Have a look here for an example that stores a value (the number of times the ESP was booted) in flash.
            • yelloweliseY Offline
              yellowelise
              How many cycle before dead of flash partition?
                cepics
                I would like to save some variables, like I did with EEPROM on esp8266, but on M5Stack sd.. (to kill sd card instead of esp32 memory)
                I'm trying this sketch:
                // http://forum.m5stack.com/topic/184/problems-writing-to-sd-card
                #include <M5Stack.h>
                //Micro SD / TF Card Test
                String cal;
                String lum;
                String unit;
                bool brght = 0;
                bool ftmt = 1;
                int x = 1680;
                void listDir(fs::FS &fs, const char * dirname, uint8_t levels) {
                  // Print blank line on screen
                  M5.Lcd.printf(" \n  ");
                  Serial.printf("Listing directory: %s\n", dirname);
                  M5.Lcd.printf("Listing directory: %s\n", dirname);
                  File root = fs.open(dirname);
                  if (!root) {
                    Serial.println("Failed to open directory");
                    M5.Lcd.println("Failed to open directory");
                    return;
                  if (!root.isDirectory()) {
                    Serial.println("Not a directory");
                    M5.Lcd.println("Not a directory");
                    return;
                  File file = root.openNextFile();
                  while (file) {
                    if (file.isDirectory()) {
                      Serial.print("  DIR : ");
                      M5.Lcd.print("  DIR : ");
                      Serial.println(file.name());
                      M5.Lcd.println(file.name());
                      if (levels) {
                        listDir(fs, file.name(), levels - 1);
                    } else {
                      Serial.print("  FILE: ");
                      M5.Lcd.print("  FILE: ");
                      Serial.print(file.name());
                      M5.Lcd.print(file.name());
                      Serial.print("  SIZE: ");
                      M5.Lcd.print("  SIZE: ");
                      Serial.println(file.size());
                      M5.Lcd.println(file.size());
                void readFile(fs::FS &fs, const char * path) {
                  Serial.printf("Reading file: %s\n", path);
                  M5.Lcd.printf("Reading file: %s\n", path);
                  File file = fs.open(path);
                  if (!file) {
                    Serial.println("Failed to open file for reading");
                    M5.Lcd.println("Failed to open file for reading");
                    return;
                  Serial.print("Read from file: ");
                  M5.Lcd.print("Read from file: ");
                  while (file.available()) {
                    int ch = file.read();
                    Serial.write(ch);
                    M5.Lcd.write(ch);
                void writeFile(fs::FS &fs, const char * path, const char * message) {
                  Serial.printf("Writing file: %s\n", path);
                  M5.Lcd.printf("Writing file: %s\n", path);
                  File file = fs.open(path, FILE_WRITE);
                  if (!file) {
                    Serial.println("Failed to open file for writing");
                    M5.Lcd.println("Failed to open file for writing");
                    return;
                  if (file.print(message)) {
                    Serial.println("File written");
                    M5.Lcd.println("File written");
                  } else {
                    Serial.println("Write failed");
                    M5.Lcd.println("Write failed");
                  Wire.begin();
                  Serial.begin(115200);
                  // Lcd display
                  M5.Lcd.setBrightness(100);
                  M5.Lcd.fillScreen(BLACK);
                  M5.Lcd.setCursor(0, 10);
                  M5.Lcd.setTextColor(WHITE);
                  M5.Lcd.setTextSize(2);
                  // Page Header
                  M5.Lcd.setCursor(0, 05);
                  M5.Lcd.printf("Testing SD Card Functions:\r\n");
                  cal = String("cal = ") + String(x) + "\r\n";
                  lum = String("lum = ") + String(brght) + "\r\n";
                  unit = String("unit = ") + String(ftmt) + "\r\n";
                  writeFile(SD, "/cal.txt", cal.c_str()); // questa funziona!!!!
                  writeFile(SD, "/lum.txt", lum.c_str()); // questa funziona!!!!
                  writeFile(SD, "/unit.txt", unit.c_str()); // questa funziona!!!!
                  M5.Lcd.printf("");
                  readFile(SD, "/cal.txt");
                  readFile(SD, "/lum.txt");
                  readFile(SD, "/unit.txt");
                  // put your main code here, to run repeatedly:
                  M5.update();
                but I can't understand how to read from sd and use the variables in the sketch..
                I need to read and write two boolean state and one int variables ..
                I'm a newbi and all the sketch I found on line that use sd.h library doesn't work on M5Stack
                if I upload read/write arduino sd example, this is the serial monitor output:
                error opening test.txt
                please help
                thanks a lot
                  cepics @yellowelise
                  @yellowelise said in arduino save int variable value:
                  I'm interested too
                    ajb2k3 @cepics
                    @cepics
                    Have you tried playing with the sd read and write examples?
                      cepics @ajb2k3
                      @ajb2k3 said in arduino save int variable value:
                      @cepics
                      yes this one
                        SD card read/write
                       This example shows how to read and write data to and from an SD card file
                       The circuit:
                       * SD card attached to SPI bus as follows:
                       ** MOSI - pin 11
                       ** MISO - pin 12
                       ** CLK - pin 13
                       ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
                       created   Nov 2010
                       by David A. Mellis
                       modified 9 Apr 2012
                       by Tom Igoe
                       This example code is in the public domain.
                      #include <SPI.h>
                      #include <SD.h>
                      File myFile;
                        // Open serial communications and wait for port to open:
                        Serial.begin(9600);
                        while (!Serial) {
                          ; // wait for serial port to connect. Needed for native USB port only
                        Serial.print("Initializing SD card...");
                        if (!SD.begin(4)) {
                          Serial.println("initialization failed!");
                          while (1);
                        Serial.println("initialization done.");
                        // open the file. note that only one file can be open at a time,
                        // so you have to close this one before opening another.
                        myFile = SD.open("test.txt", FILE_WRITE);
                        // if the file opened okay, write to it:
                        if (myFile) {
                          Serial.print("Writing to test.txt...");
                          myFile.println("testing 1, 2, 3.");
                          // close the file:
                          myFile.close();
                          Serial.println("done.");
                        } else {
                          // if the file didn't open, print an error:
                          Serial.println("error opening test.txt");
                        // re-open the file for reading:
                        myFile = SD.open("test.txt");
                        if (myFile) {
                          Serial.println("test.txt:");
                          // read from the file until there's nothing else in it:
                          while (myFile.available()) {
                            Serial.write(myFile.read());
                          // close the file:
                          myFile.close();
                        } else {
                        // nothing happens after setup
                      it compile but the serial monitor say:
                      right now, with an example from here, I can write an int variable in a file on sd
                      int cal = 2000;
                        Wire.begin();
                        File file = SD.open("/cal.txt", FILE_WRITE);
                        if (!file) {
                          return;
                        if (file.print(cal)) {
                        } else {
                      and I can read the file with
                      int ch;
                        Wire.begin();
                        File file = SD.open("/cal.txt");
                        if (!file) {
                          return;
                          ch = file.read();
                          Serial.write(ch);
                          M5.Lcd.write(ch);
                      but I can't use the "ch" variable ..
                      if I add, on the "read" sketch
                      int y = ch + 2000;
                      Serial.print(y);
                      in the serial monitor I have:
                      M5Stack initializing...O�������
                      Read from file: 2000
                      2048
                      2048 instead of 4000
                      now I'm searching how to convert ASCII to binary
                      thanks for interest..
                        heybin
                        Hello,if you want use eeprom, suggest try this example in arduino ide:
                        file->Examples->Preferences
                        https://github.com/espressif/arduino-esp32/blob/master/libraries/Preferences/examples/StartCounter/StartCounter.ino
                          cepics
                          the solution:
                          file.parseInt();
                          thanks a lot !!!
