M5Paper Factory Software?
Is it possible to re-install the default software that comes with M5Paper? Is the source code available anywhere?
thanks! -
The Precompiled binary is in the M5Burner firmware burner program along with other precompiled firmwares.
Hello I am a bit lost. I uploaded some complex m5f file to the M5 since then it is only showing blank screen i can get it connected too UIflow it however doesn't show inkt updates anymore. I installed the factory test from Burner and from the website still only shows a blank screen any ideas on how to get it back to showing things?
Did you click on the "Erase" button in M5Burner before burning the correct M5Paper firmware?
