M5Paper Factory Software?
 Is it possible to re-install the default software that comes with M5Paper? Is the source code available anywhere?
 thanks!
 The Precompiled binary is in the M5Burner firmware burner program along with other precompiled firmwares.
 Hello I am a bit lost. I uploaded some complex m5f file to the M5 since then it is only showing blank screen i can get it connected too UIflow it however doesn't show inkt updates anymore. I installed the factory test from Burner and from the website still only shows a blank screen any ideas on how to get it back to showing things?
 Did you click on the "Erase" button in M5Burner before burning the correct M5Paper firmware?
