    195 Posts 79 Posters 571.1k Views 13 Watching
      flex @flex
      @flex
      And also rhrough the uIFlow cloud it is ok to develop through an ipad as it doesn’t offer USB-C to serial
        @IAMLIUBO Error with the TOF Unit with Alpha7
        Connected to Serial Port!
        >>> import gc
        >>> gc.collect()
        === import os, sys, io
        === import M5
        === from M5 import *
        === from hardware import *
        === from unit.tof import ToF
        === from unit import *
        === title0 = None
        === label0 = None
        === i2c0 = None
        === tof_0 = None
        === def setup():
        ===   global title0, label0, i2c0, tof_0
        ===   i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000)
        ===   tof_0 = ToF(i2c0)
        ===   M5.begin()
        ===   title0 = Widgets.Title("Title", 3, 0xFFFFFF, 0x0000FF, Widgets.FONTS.DejaVu18)
        ===   label0 = Widgets.Label("Text", 23, 58, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        ===   title0.setText('TOF Unit')
        ===   label0.setFont(Widgets.FONTS.DejaVu9)
        === def loop():
        ===   M5.update()
        ===   label0.setText(str(((str('Distance: ') + str((tof_0.get_distance()))))))
        ===   try:
        ===     setup()
        ===     while True:
        ===       loop()
        ===     try:
        ===       print_error_msg(e)
        ===     except ImportError:
          File "<stdin>", line 28, in <module>
          File "<stdin>", line 23, in loop
          File "driver/vl53l0x.py", line 521, in get_distance
        AttributeError: 'VL53L0X' object has no attribute 'range'
          flex @flex
          @flex @IAMLIUBO @ajb2k3
          bug in "get UTC time" and "get system uptime in seconds" for AtomS3 and UIFlow2/micropython 1.19.1 is probably related to a confusion handling Unix time 1970 and Unix time 2000 (as 30 years difference returned)
          • teastainT Offline
            teastain @IAMLIUBO
              ajb2k3 @flex
              @flex Some people and groups cant use the cloud platform and so local programming like with the microbic and RPI is needed for them
              S W 2 Replies Last reply Reply Quote 0
                sgu @ajb2k3
                This is true. If you build an internal application for a company on the internal network, the devices will not have cloud access or they have to switch always the wlan.
                A Desktop uiflow version is still a good alternative to the cloud version !
                  sgu
                  Ui Flow 2.0 looks nice. But it lacks functionality.
                  Tested with a new Core S3 and wanted to test out the built in Camera. But how to do it either in micropython or with blockly ?
                  Once you start selling the devices, the software must be ready and support all features of the device.
                  In my case I wanted to test the camera if it is possible to use the built in camera as a barcode reader, this would be a great application.
                  Second question to uiflow 2.0: Where have the examples gone ?
                  Even as an experienced programme, the demos are a good starting point for testing out a device or a unit.
                  Third question: How about the support of the stackable-modules for the Core S3 ? How to access them in the UiFlow 2.0 ? can we reuse the modules for the older M5 Stack models ?
                  ajb2k3A IAMLIUBOI 2 Replies Last reply Reply Quote 0
                    ajb2k3 @sgu
                    @sgu UIFLOW2 and the S3 generation are in alpha test only. From what I can see there are some issues with the pins that could mean that modules won’t work. There are no examples because none have been made yet. I am working on documentation but as UIFlow is in alpha and prone to change then documentation is slow going including the documentation of the various API’S buried in the firmware.
                    • DR_Froggy_rDD Offline
                      DR_Froggy_rD
                      Hi there,
                      I tried to do something but uiflow2 is somehow confusing:
                      I was able to burn uifllw 2.0 on my atom s3 thank to adam!
                      Now I wanted to play with it: so I changed the bacground colour! this worked.
                      Now I was looking to other option as he one found for the stick C plus (IMU and so on) but those are0_1687691175164_uiflow2_ no option.png not available for the atoms3...
                      0_1687691191201_uiflow1_ all options.png the second picture is from uiflow where all hardware options are listed... even the remote + options which is very promissing to me if I achieve that. but I cannot delete all at once...I cannot see the end of the window so I cannot delete everything...or clear to start from scratch on microsoft edge...
                        You need to click on "Hardware" under the picture of the Atom S3, then click on the hardware option to use it.IMU is there and was working.
                          DR_Froggy_rD
                          I see- the page view was cropped too tight..
                          I did reset those now I see those...
                          this is idiotic but ar least I can get it now.
                          I wanted to get the remote +
                          Will it be enable in the future?
                            alas, I don't know
                              DR_Froggy_rD
                              alas, I don't know
                              what people use instead?
                              • IAMLIUBOI Offline
                                IAMLIUBO @sgu
                                @sgu said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
                                New firmware support camera now :-)
                                Now it only supports basic functions such as image display, and does not support high-level functions such as recognizing barcodes.
                                We will add the example as soon as possible. Considering that it is still in the alpha stage, we still need to do the final API review. In short, we will add the example as soon as possible.
                                Yeah, any module or uint or hat will support in uiflow2.0, just need a little time to made this, sorry for this, we will do our best.
                                • IAMLIUBOI Offline
                                  IAMLIUBO @teastain
                                  @teastain said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
                                  This issue? Seem fixed, thanks for report this!
                                    Hello guys
                                    I think in addition to the filters it would be beneficial to have some sort of sort order (e.g. alphabetically) for items listed under Software, Hardware and Unit.
                                    The reason I am asking is that often times (also in UIFlow 1) I scroll through the Unit list up and down; missing the one unit I want to add multiple times before finally spotting it.
                                      jhd2023
                                      for the UI, it would really be a work-saver if you could create multiple UI pages that can then be easily switched.
                                      IAMLIUBOI 1 Reply Last reply Reply Quote 2
                                        joeoakes
                                        Is there an estimated date when micropython code deploying/running using UiFlow 2.0 to the S3 will be supported? All our projects are written in micropython for the S2 and we cannot migrate over to the S3.
                                          S3 devices are supported as that was the reason five the UIFlow2 version.
                                            Hello @IAMLIUBO
                                            M5CoreS3 - UIFlow2 alpha 21 - SDCard issues:
                                            • the Init SDCard with block has everything pre-selected correctly except for CS. It should be GPIO4 (not GPIO3).
                                            • when the program is Run a second time, it stops at the Init SDCard with block. I guess that is because the SDCard has already been initialized. After that the M5CoreS3 needs to be reset manually. What am I missing?
                                            Apart from that I can access the SDCard and show the listing on the screen.
