    New module - SDP3x differential pressure sensor.
    Features Wish List
    6
    4.9k
    • B
      bluecobras09
      Would love to be able to use the M5Stack infrastructure to create a monitor for my HVAC filters to alert when it is time to change filters.
      ajb2k3A 1 Reply Last reply Reply Quote 7
        ajb2k3 @bluecobras09
        @bluecobras09
        Hello.
        What have you researched so far in order to connect to your HVAC?
        • B
          bluecobras09 @ajb2k3
          @ajb2k3 Planning on small connections on each side of the filter to connect to the sensor itself. Have not looked much beyond that do to time constraints. I have ordered an SDP3x breakout from sparkfun, hoping to do some additional research soon.
          ajb2k3A teastainT 2 Replies Last reply Reply Quote 0
            @bluecobras09 you need to reserch how it communicates and if there is a Micropython library for it and if not you need to learn how to create a library
            • teastainT
              teastain @bluecobras09
              @bluecobras09 Hi. Do you plan on programming in Arduino IDE or UIFlow (Python)? The sensor is i2c using qwiic cables and would be easy to program in Arduino, but quite a task to do in UIFlow or Python.
              -Terry
              • M Maecksu referenced this topic on
                Maecksu
                There's a similar request here:
                https://community.m5stack.com/topic/6215/product-revision-tube-air-pressure-unit-with-i2c
