    M5Stack Core S3
    PRODUCTS
    8
    6.0k
    • B
      Bipman
      Hi.
      I have a Core S3 and am programming it with the Arduino IDE. When I compile I get
      *D:\Users\steph\Arduino\SPG\Gloving\Gloving_Pressure\Gloving_Pressure_M5StackCore23\Gloving_Pressure_M5StackCore23.ino:6:10: fatal error: M5CoreS3.h: No such file or directory
      #include <M5CoreS3.h>
      compilation terminated.
      exit status 1
      Compilation error: M5CoreS3.h: No such file or directory*
      I've added the M5Stack board and in the preferences too. I must have missed something somewhere as the Core S2 works fine. Any ideas?
      Steve
      • teastainT
        teastain @Bipman
        @bipman
        Did you #include <M5CoreS3.h> ?
        The complete repository is here:
        https://github.com/m5stack/M5CoreS3
        and the library here;
        https://github.com/m5stack/M5CoreS3/tree/main/src
        • B
          Bipman
          Hi
          I did, yes but it seems to not exist. I found the library but I do not know how to add it in to the Arduino IDE.
          Steve
          • B
            Bipman
            OK, I've now added the library but I am now getting 'fatal error: BMI270_Sensor.h: No such file or directory
            #include "BMI270_Sensor.h"' when I compile any of the test programs. I've loaded the BMI270 library but I suspect the Arduino one is not the correct one. Any ideas?
            Steve
              Hello @Bipman
              you'll need this one.
              • B
                Bipman
                That worked thanks! Any other gotchas likely? Also, is there an M5 stack CoreS3 api guide? I couldn't find one anywhere.
                Steve
                  ajb2k3 @Bipman
                  @bipman Not for the Arduino but a micropython guide is on its way.
                  • B
                    Bipman
                    OK, thanks.
                    Steve
