    195 Posts 79 Posters 551.2k Views 13 Watching
    • IAMLIUBOI Offline
      IAMLIUBO @felmue
      @felmue said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
      code modifications in Python view are lost without warning when switching back to block view.
      Mark this, and will fix this.
      in split view: which code will actually be executed? Block view or Python view?
      For now, python area is only for look, any editing will reset when you click run button, will add lock button in the future. emmmm, in split view mode, if has some choose button will be better? User can choose which one to execute? We will talk this.
      Thanks @felmue !
        mchott
        For now it´s nearly the same like before and maybe the biggest innovations are in restructuring the UI and "under the UI".
        There is still no multiple views feature to make the display more usefull with the UIFlow?
        • IAMLIUBOI Offline
          IAMLIUBO
          @mchott said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
          yeah, multiple views feature I also want make it, pls give my team sometime, i think one day we can make it happen. We still have a lot of basic functionality to add for now.
            Jruys
            Potential bug: When I add a function, any blocks in there seem to go "disabled" - I have to manually enable every bit of it. After saving and loading, all blocks are disabled again.
            Am I missing something?
            Thanks - JW
            • IAMLIUBOI Offline
              IAMLIUBO @Jruys
              @jruys
              Sorry for that happened, we'll look into this.
                flex
                Bug in "get UTC time"
                • year returned is +30 (2053 instead of 2023)
                • month is OK
                • day returned is -1 (17 instead or 18)
                • hour is OK
                • minute is OK
                Bug in "get system uptime in seconds"
                • value is increasing correctly second by second but the value returned is HUGE!!!
                  flex
                  problem with some m5Burner version 3 on OSX:
                  different versions where released on the website but they are all identified 3.0.0, which is confusing...
                  • the one of April 9 2022, which doesn't work with atomS3
                  • the one of January 13 2023 which works
                  you should increased the last one to 3.0.1 to avoid any confusion for long time users
                  Pascal
                    flex
                    Could you unlock from UIFlow 2 the capability to code in micropython…
                      ajb2k3 @flex
                      @flex What do you mean as you can work direct in micropython without UIFlow using REPL
                        @IAMLIUBO With the S3's having the internal USB adapter, the S3's can now act as USB drives.
                        Can we get a UF2 boot loader so that Stamp and Atom S3's can now be programmed like Microbit and Circuitpython devices (USB storage devices.)
                          flex @ajb2k3
                          UIFlow make it easier to upload and test code through the cloud and also to draft the screen UI on the atomS3
                          F ajb2k3A 2 Replies Last reply Reply Quote 0
                            flex @flex
                            @flex
                            And also rhrough the uIFlow cloud it is ok to develop through an ipad as it doesn’t offer USB-C to serial
                              @IAMLIUBO Error with the TOF Unit with Alpha7
                              Connected to Serial Port!
                              >>> import gc
                              >>> gc.collect()
                              === import os, sys, io
                              === import M5
                              === from M5 import *
                              === from hardware import *
                              === from unit.tof import ToF
                              === from unit import *
                              === title0 = None
                              === label0 = None
                              === i2c0 = None
                              === tof_0 = None
                              === def setup():
                              ===   global title0, label0, i2c0, tof_0
                              ===   i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000)
                              ===   tof_0 = ToF(i2c0)
                              ===   M5.begin()
                              ===   title0 = Widgets.Title("Title", 3, 0xFFFFFF, 0x0000FF, Widgets.FONTS.DejaVu18)
                              ===   label0 = Widgets.Label("Text", 23, 58, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                              ===   title0.setText('TOF Unit')
                              ===   label0.setFont(Widgets.FONTS.DejaVu9)
                              === def loop():
                              ===   M5.update()
                              ===   label0.setText(str(((str('Distance: ') + str((tof_0.get_distance()))))))
                              ===   try:
                              ===     setup()
                              ===     while True:
                              ===       loop()
                              ===     try:
                              ===       print_error_msg(e)
                              ===     except ImportError:
                                File "<stdin>", line 28, in <module>
                                File "<stdin>", line 23, in loop
                                File "driver/vl53l0x.py", line 521, in get_distance
                              AttributeError: 'VL53L0X' object has no attribute 'range'
                                flex @flex
                                @flex @IAMLIUBO @ajb2k3
                                bug in "get UTC time" and "get system uptime in seconds" for AtomS3 and UIFlow2/micropython 1.19.1 is probably related to a confusion handling Unix time 1970 and Unix time 2000 (as 30 years difference returned)
                                • teastainT Offline
                                  teastain @IAMLIUBO
                                    ajb2k3 @flex
                                    @flex Some people and groups cant use the cloud platform and so local programming like with the microbic and RPI is needed for them
                                    S W 2 Replies Last reply Reply Quote 0
                                      sgu @ajb2k3
                                      This is true. If you build an internal application for a company on the internal network, the devices will not have cloud access or they have to switch always the wlan.
                                      A Desktop uiflow version is still a good alternative to the cloud version !
                                        sgu
                                        Ui Flow 2.0 looks nice. But it lacks functionality.
                                        Tested with a new Core S3 and wanted to test out the built in Camera. But how to do it either in micropython or with blockly ?
                                        Once you start selling the devices, the software must be ready and support all features of the device.
                                        In my case I wanted to test the camera if it is possible to use the built in camera as a barcode reader, this would be a great application.
                                        Second question to uiflow 2.0: Where have the examples gone ?
                                        Even as an experienced programme, the demos are a good starting point for testing out a device or a unit.
                                        Third question: How about the support of the stackable-modules for the Core S3 ? How to access them in the UiFlow 2.0 ? can we reuse the modules for the older M5 Stack models ?
                                        ajb2k3A IAMLIUBOI 2 Replies Last reply Reply Quote 0
                                          ajb2k3 @sgu
                                          @sgu UIFLOW2 and the S3 generation are in alpha test only. From what I can see there are some issues with the pins that could mean that modules won’t work. There are no examples because none have been made yet. I am working on documentation but as UIFlow is in alpha and prone to change then documentation is slow going including the documentation of the various API’S buried in the firmware.
                                          • DR_Froggy_rDD Offline
                                            DR_Froggy_rD
                                            Hi there,
                                            I tried to do something but uiflow2 is somehow confusing:
                                            I was able to burn uifllw 2.0 on my atom s3 thank to adam!
                                            Now I wanted to play with it: so I changed the bacground colour! this worked.
                                            Now I was looking to other option as he one found for the stick C plus (IMU and so on) but those are0_1687691175164_uiflow2_ no option.png not available for the atoms3...
                                            0_1687691191201_uiflow1_ all options.png the second picture is from uiflow where all hardware options are listed... even the remote + options which is very promissing to me if I achieve that. but I cannot delete all at once...I cannot see the end of the window so I cannot delete everything...or clear to start from scratch on microsoft edge...
