    M5 Stick C IMU orientation
    M5 Stick/StickC
    6.4k
    • D
      Drew P
      Hi everyone,
      Probably a really daft question but i can’t find an orientation diagram for the Stick C for the IMU with regard to its case!
      I’ve searched everywhere to no joy. A simple diagram with regard to looking at the screen where xyz are pointing
      I’m trying to use the C as a reference for an IMU grove sensor using a rotating image of a block
      • teastainT
        teastain @Drew P
        @drew-p Simple answer to any IMU:
        Just put it flat on a surface. The axis that shows ~ 1.00 is 1 gravity, the others should be ~ 0.00
        Shown here is the AtomS3 built-in IMU with the third reading (az) showing "1g" .
        You can roll it on its side to see x or y.
        Hope this helps.
        -Terry
        • D
          Drew P
          May not understand what l meant. I need to know what orientation is for X Y Z with regard to the stick
          Does X lie along the long axis of the case or the short so Y would be the other way.
          I’m assuming that Z is from front to back, I.e screen to rear label but I need to know the directions of X and Y
          There’s a diagram on Grove IMU sensor but nothing on the Stick C
          • D
            Drew P @teastain
            @teastain thanks for your reply but I’m after the orientation of XYZ on the Stick C. Does X run along the long axis, from usb connection to other end, or from side to side?
            I assume Z is from screen to base where label is
            Can’t find anything in the documentation, or I’ve missed it!
            Thanks again
            Drew
            • teastainT
              teastain @Drew P
              My advice works on any IMU on any microcontroller.
              You can figure it out yourself, it's fun and part of the challenge.!0_1674873297510_StickIMU copy.jpg
              Lying flat on the bench, "UP" (towards the camera) is Z axis. Rotate to side and on end to determine other axes.
              • D
                Drew P @teastain
                @teastain thank you. I’ll try it tomorrow
                • teastainT
                  teastain @Drew P
                  @drew-p From the IMU mfg. website:
                    I'm sure that the IMU is place so that Y points to the top of the StickC.
