M5Station lack of support .. or am I looking in the wrong place !
Just started using M5Stack last Thursday but pretty impressed I now have a monitoring setup recording 6 analogue add-on channels and successfully reading the data in Qubitro. But is the M5StationBAT a new product as I can find very little on it on the internet specific to that unit and a there seems a scant lack of documentation. For instance having achieved what I basically needed for my project, I am now completely stuck with simple basic tasks ... for example how do you drive the 7 LED's on this unit?
@ashimotok0
What program language are you using?
Alas I can only use mine from command line as I lost my display -
Hello @AshimotoK0
have a look at the factory test code or the example I've created.
General information about M5Station can be found here.
Felix -
@ajb2k3 Thanks I am using UIFlow
Hello @AshimotoK0
ok, in that case, in UIFlow, have you tried to use the RGB blocks under Hardware to control the 7 LEDs?
Felix -
@felmue ..Thanks for that a colleague sussed that out just before I read your reply but many thanks as you were dead right... as all up and running now. For anyone reading this reply the illumination of the centre main on/off button is LED #4 I didn't realize that the LED's are multi colour until I studied the circuit diagram/schematic ...cool !
