    V-Training Service is active now??
    Scheduled Pinned Locked Moved M5Stick V
    v-training
    12 Posts 7 Posters 26.0k Views 1 Watching
    • N Offline
      Nabeshin
      Thank you.
      This is not serious at all.
      I will try it again in next year.
      Have nice holidays!!!
      • N Offline
        Nabeshin
        @Zontex
        Now I can upload files. But Training always fails with this error.
        CONTENT: Unexpected Error Found During Triaining, A target array with shape (128, 6) was passed for an output of shape (None, 7) while using as loss categorical_crossentropy. This loss expects targets to have the same shape as the output.
        I uploaded following data.
        • 6 classes training data
        • Each class has 90 files(85 files in train folder. 5 + 1 files in each valid folder)
          • At first, using the result folder created by UnitV_boot_v1220.py, I got Error: Lake of Enough Valid Dataset, Only 30 pictures found, but you need 35 in total.
          • Maybe Lake of is typo of Lack of I think.
          • So I moved 1 file manually from train folder to valid folder for each class.(Then I made 5 + 1 files in each valid folder.(Total 36 in valid folder)
          • Then that goes fine.
        • But now I got that error about categorical_crossentropy .
          • I tried several cases and got same kind of error.
          • For 6 class case: A target array with shape (128, 6) was passed for an output of shape (None, 7)
          • For 4 class case: A target array with shape (64, 4) was passed for an output of shape (None, 5)
        I'm not sure but I think it's because,
        • At model.add(Dense(X)) script, X should be the same number of uploaded class folders of each request.
        • But maybe it is over counted from exact one in your script.
          • https://github.com/keras-team/keras/issues/3237
        Do you have any idea for fix it?
        Regards.
        • N Offline
          Nabeshin
          @Zontex
          Hi, I tried again now but It seems like still having problems...
          Can I build same environment in my computer?
          What should I install for this machine learning?
          If you can point the GitHub URL, Please let me help.
          Regards.
          • N Offline
            Nabeshin
            Hi, Now I got one solution by myself.
            We can build a private environment of K210 machine learning on Goggle colaboratory.
            Of course we can share.
            I wrote an article here.
            This can be used as an another way of V-Training for M5StickV and M5UnitV.
            Qiita
            • https://qiita.com/Nabeshin/items/d526a94b8f3be85bbb05
            Goggle colaboratory
            • https://colab.research.google.com/drive/1UdQV5nQMQy1ckJP0qdS3kS7sW6sEQyzs#scrollTo=prOt_VofnYCo
            Thank you.
            • Y Offline
              yossy
              @Zontex
              Hi, I am now facing the same issue now.
              My task (No .10: 2d37a16258bdaee3) does not finish... and No.1 which was uploaded in 5/7/2021 seems not finished yet. so is it possible to know the current situation? thank you in advance.
              • m5stackM Online
                m5stack @yossy
                @yossy sorry about that.. seems the server has some problem. we are working on it now.
                Y 1 Reply Last reply Reply Quote 1
                • Y Offline
                  yossy @m5stack
                  @m5stack Thank you for your notice. I could check that the system is working correctly now. Thank you!
                    kenkenissocool
                    @m5stack
                    My task (No .2: 288ab05e8953e901) does not finish... and No.1 which was uploaded in 3/12/2022 seems not finished yet. so is it possible to know the current situation? thank you in advance.
                      class14
                      Do I have the same problem if mine says waiting since yesterday?
                        Harvestman
                        I'm also waiting on this. It looks like there are items in the queue since 12/2/2022.
