    V-Training Service is active now??
    Scheduled Pinned Locked Moved M5Stick V
    v-training
    12 Posts 7 Posters 25.4k Views 1 Watching
    • N Offline
      Nabeshin
      I uploaded files to the V-Training service but it seems not running....
      Currently Task No.6(2020/12/29) is mine,
      but task No.1 which was uploaded in 2020/12/24 still remaining.
      Anyone can help please?
      http://v-training.m5stack.com
      Thank you.
      • ZontexZ Offline
        Zontex @Nabeshin
        @nabeshin said in V-Training Service is active now??:
        Hi, we are aware of that and working to fix it ASAP.
        • N Offline
          Nabeshin
          Thank you.
          This is not serious at all.
          I will try it again in next year.
          Have nice holidays!!!
          • N Offline
            Nabeshin
            @Zontex
            Now I can upload files. But Training always fails with this error.
            CONTENT: Unexpected Error Found During Triaining, A target array with shape (128, 6) was passed for an output of shape (None, 7) while using as loss categorical_crossentropy. This loss expects targets to have the same shape as the output.
            I uploaded following data.
            • 6 classes training data
            • Each class has 90 files(85 files in train folder. 5 + 1 files in each valid folder)
              • At first, using the result folder created by UnitV_boot_v1220.py, I got Error: Lake of Enough Valid Dataset, Only 30 pictures found, but you need 35 in total.
              • Maybe Lake of is typo of Lack of I think.
              • So I moved 1 file manually from train folder to valid folder for each class.(Then I made 5 + 1 files in each valid folder.(Total 36 in valid folder)
              • Then that goes fine.
            • But now I got that error about categorical_crossentropy .
              • I tried several cases and got same kind of error.
              • For 6 class case: A target array with shape (128, 6) was passed for an output of shape (None, 7)
              • For 4 class case: A target array with shape (64, 4) was passed for an output of shape (None, 5)
            I'm not sure but I think it's because,
            • At model.add(Dense(X)) script, X should be the same number of uploaded class folders of each request.
            • But maybe it is over counted from exact one in your script.
              • https://github.com/keras-team/keras/issues/3237
            Do you have any idea for fix it?
            Regards.
            • N Offline
              Nabeshin
              @Zontex
              Hi, I tried again now but It seems like still having problems...
              Can I build same environment in my computer?
              What should I install for this machine learning?
              If you can point the GitHub URL, Please let me help.
              Regards.
              • N Offline
                Nabeshin
                Hi, Now I got one solution by myself.
                We can build a private environment of K210 machine learning on Goggle colaboratory.
                Of course we can share.
                I wrote an article here.
                This can be used as an another way of V-Training for M5StickV and M5UnitV.
                Qiita
                • https://qiita.com/Nabeshin/items/d526a94b8f3be85bbb05
                Goggle colaboratory
                • https://colab.research.google.com/drive/1UdQV5nQMQy1ckJP0qdS3kS7sW6sEQyzs#scrollTo=prOt_VofnYCo
                Thank you.
                • Y Offline
                  yossy
                  @Zontex
                  Hi, I am now facing the same issue now.
                  My task (No .10: 2d37a16258bdaee3) does not finish... and No.1 which was uploaded in 5/7/2021 seems not finished yet. so is it possible to know the current situation? thank you in advance.
                  • m5stackM Online
                    m5stack @yossy
                    @yossy sorry about that.. seems the server has some problem. we are working on it now.
                    Y 1 Reply Last reply Reply Quote 1
                    • Y Offline
                      yossy @m5stack
                      @m5stack Thank you for your notice. I could check that the system is working correctly now. Thank you!
                        kenkenissocool
                        @m5stack
                        My task (No .2: 288ab05e8953e901) does not finish... and No.1 which was uploaded in 3/12/2022 seems not finished yet. so is it possible to know the current situation? thank you in advance.
                          class14
                          Do I have the same problem if mine says waiting since yesterday?
                            Harvestman
                            I'm also waiting on this. It looks like there are items in the queue since 12/2/2022.
