    V-Training Service is active now??
    Scheduled Pinned Locked Moved M5Stick V
    v-training
    12 Posts 7 Posters 26.0k Views 1 Watching
    • ZontexZ Offline
      Zontex @Nabeshin
      @nabeshin said in V-Training Service is active now??:
      http://v-training.m5stack.com
      Hi, we are aware of that and working to fix it ASAP.
      • N Offline
        Nabeshin
        Thank you.
        This is not serious at all.
        I will try it again in next year.
        Have nice holidays!!!
        • N Offline
          Nabeshin
          @Zontex
          Now I can upload files. But Training always fails with this error.
          CONTENT: Unexpected Error Found During Triaining, A target array with shape (128, 6) was passed for an output of shape (None, 7) while using as loss categorical_crossentropy. This loss expects targets to have the same shape as the output.
          I uploaded following data.
          • 6 classes training data
          • Each class has 90 files(85 files in train folder. 5 + 1 files in each valid folder)
            • At first, using the result folder created by UnitV_boot_v1220.py, I got Error: Lake of Enough Valid Dataset, Only 30 pictures found, but you need 35 in total.
            • Maybe Lake of is typo of Lack of I think.
            • So I moved 1 file manually from train folder to valid folder for each class.(Then I made 5 + 1 files in each valid folder.(Total 36 in valid folder)
            • Then that goes fine.
          • But now I got that error about categorical_crossentropy .
            • I tried several cases and got same kind of error.
            • For 6 class case: A target array with shape (128, 6) was passed for an output of shape (None, 7)
            • For 4 class case: A target array with shape (64, 4) was passed for an output of shape (None, 5)
          I'm not sure but I think it's because,
          • At model.add(Dense(X)) script, X should be the same number of uploaded class folders of each request.
          • But maybe it is over counted from exact one in your script.
            • https://github.com/keras-team/keras/issues/3237
          Do you have any idea for fix it?
          Regards.
          • N Offline
            Nabeshin
            @Zontex
            Hi, I tried again now but It seems like still having problems...
            Can I build same environment in my computer?
            What should I install for this machine learning?
            If you can point the GitHub URL, Please let me help.
            Regards.
            • N Offline
              Nabeshin
              Hi, Now I got one solution by myself.
              We can build a private environment of K210 machine learning on Goggle colaboratory.
              Of course we can share.
              I wrote an article here.
              This can be used as an another way of V-Training for M5StickV and M5UnitV.
              Qiita
              • https://qiita.com/Nabeshin/items/d526a94b8f3be85bbb05
              Goggle colaboratory
              • https://colab.research.google.com/drive/1UdQV5nQMQy1ckJP0qdS3kS7sW6sEQyzs#scrollTo=prOt_VofnYCo
              Thank you.
              • Y Offline
                yossy
                @Zontex
                Hi, I am now facing the same issue now.
                My task (No .10: 2d37a16258bdaee3) does not finish... and No.1 which was uploaded in 5/7/2021 seems not finished yet. so is it possible to know the current situation? thank you in advance.
                • m5stackM Online
                  m5stack @yossy
                  @yossy sorry about that.. seems the server has some problem. we are working on it now.
                  Y 1 Reply Last reply Reply Quote 1
                  • Y Offline
                    yossy @m5stack
                    @m5stack Thank you for your notice. I could check that the system is working correctly now. Thank you!
                      kenkenissocool
                      @m5stack
                      My task (No .2: 288ab05e8953e901) does not finish... and No.1 which was uploaded in 3/12/2022 seems not finished yet. so is it possible to know the current situation? thank you in advance.
                        class14
                        Do I have the same problem if mine says waiting since yesterday?
                          Harvestman
                          I'm also waiting on this. It looks like there are items in the queue since 12/2/2022.
