    M5StickC Plus and Unit Cam Wi-Fi Camera (OV2640)
    M5 Stick/StickC
    6
    7.4k
      MoodyGeorge
      I'm struggling to make it work together. I can't find any information about how to make it work. Is the Unit Cam working with M5StickC Plus ? I can see that it is greyed in the UIFlow but I don't have any info about why.
      Can someone help me getting more info about them working together or why the cam module in UIFlow is greyed ?
        Hello @MoodyGeorge
        afaik M5StickCPlus and unit cam do not work together. Possible reasons:
        • unit cam returns a jpeg picture, but M5StickCPlus library doesn't support / implement jpeg functions
        • unit cam returns a picture with size 320x240, but M5StickCPlus display is only 240x135
        I am not saying it is not possible, but it seems it has not been adapted for M5StickCPlus as I cannot find an Arduino example nor is it available in UIFlow (hence greyed out). Sorry.
        • H
          HWTaro9 @felmue
          @felmue so I’d assume that this is the same reason you can’t use it with Core2 Either?
            Hello @HWTaro9
            according to this post you can at least use it with M5Core2 using Arduino.
              MoodyGeorge
              Ok. Thanks for your answer.
                macsbug
                Hello@MoodyGeorge
                An example of adding M5.lcd.drawJpg to M5StickC.
                anoken/m5stickc_arduino.ino
                https://gist.github.com/anoken/8b0ce255e9aef9d1a7f4d46272cedcaa
                reference
                https://twitter.com/nnn112358/status/1218447646009937920
