    M5. Lcd.textWidth does not center text exactly in the middle
    6.5k
      Stoni99
      I want to write a text centered in the middle. the text has a variable size. with M5. Lcd.textWidth, the text is not centered exactly in the middle (deviation about 5px). I doing something wrong? How can I center the text in height?
      M5.Lcd.fillScreen(BLACK); //set the default background color
      M5.Lcd.fillRoundRect(20, 50, 280, 140, 15, RED);
      M5.Lcd.fillRoundRect(30, 60, 260, 120, 15, BLACK);
      M5.Lcd.setTextSize(5);
      M5.Lcd.setTextColor(RED);
      for (int i=-1500; i <= 2255; i++){
      String text = String(i);
      M5.Lcd.drawString(text, (int)((M5.Lcd.width()/2)-(M5.Lcd.textWidth(text)/2)), (int)(M5.Lcd.height()/2), 2);
      delay(20);
        macsbug
        Hello@Stoni99
        1. Use the setTextDatum and drawString instructions.
          M5.Lcd.setTextDatum(3);
          M5.Lcd.drawString(text, (int)((M5.Lcd.width()/2)-(M5.Lcd.textWidth(text)/2)-15),(int)(M5.Lcd.height()/2-0), 2);
        2. Use the drawCentreString instruction.
        // M5.Lcd.setTextSize(5);
        // M5.Lcd.drawString(text, (int)((M5.Lcd.width()/2)-(M5.Lcd.textWidth(text)/2)), (int)(M5.Lcd.height()/2), 2);
        M5.Lcd.drawCentreString(text, M5.Lcd.width()/2, M5.Lcd.height()/2-40 , 8);
          Stoni99
          OK - thank you!
          The height is therefore adjusted by hand.
          Other question:
          I can't append the "W" to the string. It is not displayed. Is there another possibility?
          String text = String(i)+"W";
          M5.Lcd.drawCentreString(text, M5.Lcd.width()/2, M5.Lcd.height()/2-30 , 7); //Text auf x zentrieren (x,y,Schriftgrösse)
          //M5.Lcd.drawString(text, (int)((M5.Lcd.width()/2)-(M5.Lcd.textWidth(text)/2)-15), (int)((M5.Lcd.height()/2)-40), 2);
          delay(1000);
            macsbug
            Hello@Stoni99
            m5-docs:LCD
            setTextDatum(), drawString(), drawCentreString()
            https://github.com/m5stack/m5-docs/blob/master/docs/en/api/lcd.md
            A. Use the drawCentreString instruction.
            drawCentreString : fontname=2
            M5.Lcd.drawCentreString(text, M5.Lcd.width()/2, M5.Lcd.height()/2 -42 , 2);
            or
            M5.Lcd.setTextSize(4);
            M5.Lcd.drawCentreString(text, M5.Lcd.width()/2, M5.Lcd.height()/2 -34 , 2);
            B. setTextDatum + drawString + Free_Fonts
            Free_Fonts.h : Beautiful font.
            https://github.com/m5stack/M5Stack/blob/master/examples/Advanced/Display/Free_Font_Demo/Free_Fonts.h
            #include <Free_Fonts.h>
            void setup(){
            M5.Lcd.setFreeFont(FMB24); // or FM24
            void loop(){
            M5.Lcd.setTextSize(1);
            M5.Lcd.drawString(text, M5.Lcd.width()/2-M5.Lcd.textWidth(text)/2, M5.Lcd.height()/2 -3,1);
              Stoni99
              👍Thank you!
