    M5Burner does not work in MacOX 12.3.
    m5 burneruiflow
    18 Posts 12 Posters 34.0k Views 5 Watching
    • B Offline
      Boomvalt
      Same problem here. Program become non-responsive, requires Force Quit.
      • L Offline
        lmartu68
        I tried re installing python 3 and running the executable from the command line but I get a Java error
        Has anyone got this to work?
        Its frustrating!
        • L Offline
          lmartu68
          this is the error I get
          Uncaught Exception:
          Error: spawn python ENOENT
          at Process.ChildProcess._handle.onexit (internal/child_process.js:264:19)
          at onErrorNT (internal/child_process.js:456:16)
          at processTicksAndRejections (internal/process/task_queues.js:80:21)
          • Y Offline
            yopita
            I had the same problem.
            I referred to joshrhyked's post, and I succeed burn with the following steps.
            1. Start Terminal App.
            2. Install homebrew.
              Please refer to the installation on the page.
              https://brew.sh/
            3. Install python3
              Please type the command.
              $ brew install python3
            4. Put a symbolic link
              $ sudo ln -s /usr/local/bin/python3 /usr/local/bin/python
            5. Start M5Burner on Terminal
              $ /Applications/M5Burner.app/Contents/MacOS/electron-m5burner-v2-eletron
            best of luck to you!
            ajb2k3A W 2 Replies Last reply Reply Quote 3
              ajb2k3 @yopita
              @yopita said in M5Burner does not work in MacOX 12.3.:
                https://brew.sh/
              3. Install python3
              Step 4 is not correct but I see it worked for you.
              Open terminal and go to settings, you should be able to add /usr/local/bin/python3 to the environmental setting or find the environmental file and add it it there.
              • W Offline
                waqast @yopita
                @yopita
                https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139#issuecomment-1014816668
                It worked for me
                System:
                MacOS Monterey 12.3.1 (Macbook Pro 2019 Intel)
                Device
                M5Stack Core2
                • Install the driver CH9102_VCP_MacOS_v1.7 > CH34xVCPDriver.pkg
                • Run the app CH34xVCPDriver in Applicatoins
                • GO TO Security on Settings and allow the app to run
                • Start Terminal App.
                • Install homebrew.
                  Please refer to the installation on the page : https://brew.sh/
                • Install python3
                • Put a symbolic link
                • Start M5Burner on Terminal
                • Select COM port wchusbmodem
                W R 2 Replies Last reply Reply Quote 0
                • W Offline
                  westwoodhk @waqast
                  @waqast
                  I couldn't solve it.
                  When I input this command
                  it comes out this message
                  ln: /usr/local/bin/python: File exists
                  Do someone know how to solve this?
                    You need to set the path in BASH's environment setting (if bash is still used) google for setting Micropython Environmental Patch in OSX. I can't help because my OSX is several version behind and won't be updated until I can afford to by a new MAC.
                      rickkaye @waqast
                      @waqast When I follow these instructions, wchusbmodem does not show up as an available port in M5Burner. I checked in /dev and it is not there. The only port that M5Burner offers to me is /dev/tty.Bluetooth-Incoming-Port. My hardware is 2017 iMac5k MacOS Monterey12.3.1, M5Stack Core. Can anyone help?
                      oyoujiO ajb2k3A 2 Replies Last reply Reply Quote 0
                      • oyoujiO Offline
                        oyouji @rickkaye
                        @rickkaye Try to turn M5stack off, then plug it in! Do not turn it on by yourself.
                          ajb2k3 @rickkaye
                          @rickkaye Take a look in "Security and preferences" to see if the driver has been blocked.
                            plusulli
                            I updated today to macOS Monterey V 12.3.1 and everything is fine with M5Burner MacOS x64 v3.0
                              mashimolab
                              hello,
                              I could resolve the problem by changing the part of putting a symbokic link like below.
                              sudo ln -s /opt/homebrew/bin/python3 /usr/local/bin/python
                              The install path of python3 with homebrew is changed to /opt/homebrew/bin directory as the default in M1 mac.
                              System:
                              MacOS Monterey 12.3.1 (Macbook Pro 2021 M1 Pro Max)
                              Device
                              M5Stack Fire
                              • Y Offline
                                yu_with_a_mission
                                @yopita
                                I tried you way and get another error,
                                "File"/Applications/M5Burner.app/Contents/Resources/packages/tools/serial/tools/list_ports_osx.py", line 32, in <module>
                                kIOMasterPortDefault = ctypes.c_void_p.in_dll(iokit, "kIOMasterPortDefault")
                                Burn Failed
                                How can I solve?
                                System:
                                MacOS Monterey 12.4
                                Device:
                                M5StickCPlus
                                  ajb2k3 @yu_with_a_mission
                                  @yu_with_a_mission said in M5Burner does not work in MacOX 12.3.:
                                  @yopita
                                  Burn Failed
                                  How can I solve?
                                  System:
                                  MacOS Monterey 12.4
                                  Device:
                                  M5StickCPlus
                                  There is an Issue Montery.
                                  Have you installed Xcode from the App Store?
                                  Have you instilled the latest Python 3 from the python site?
                                  Have you installed the drivers?
                                  Have you set the PATH variable correctly?
                                  Have you copied the M5Burner V3 to the Applications folder?
                                  Have you erased the controller first before writing the correct firmware?
