    M5Burner does not work in MacOX 12.3.
    Bug Report
    m5 burner uiflow
    12
    18
    29.6k
    • oyoujiO
      oyouji
      Hi, everyone!
      M5Burner does not work in MacOX 12.3. I checked it to work in 12.2. I heard 12.3 deletes python module. I tried to install python2 to run M5 Burner. But it does not work. I would like to use UI Flow. So, M5burner need to install UI Flow. Do you have any idea?
      oyouji
      J 1 Reply Last reply Reply Quote 4
      • J
        joshrhykerd
        I can confirm this issue. I am also unable to use the M5Burner on macOS Monterey 12.3.
        • J
          joshrhykerd @oyouji
          @oyouji I found a workaround to get the M5Burner working. I installed pyenv with Homebrew and then installed python3 using pyenv. I then had to launch M5Burner from the command line so it had access to the newly installed python3. I did this buy running "/Applications/M5Burner.app/Contents/MacOS/electron-m5burner-v2-eletron".
          • B
            Boomvalt
            Same problem here. Program become non-responsive, requires Force Quit.
            • L
              lmartu68
              I tried re installing python 3 and running the executable from the command line but I get a Java error
              Has anyone got this to work?
              Its frustrating!
              • L
                lmartu68
                this is the error I get
                Uncaught Exception:
                Error: spawn python ENOENT
                at Process.ChildProcess._handle.onexit (internal/child_process.js:264:19)
                at onErrorNT (internal/child_process.js:456:16)
                at processTicksAndRejections (internal/process/task_queues.js:80:21)
                • Y
                  yopita
                  I had the same problem.
                  I referred to joshrhyked's post, and I succeed burn with the following steps.
                  1. Start Terminal App.
                  2. Install homebrew.
                    Please refer to the installation on the page.
                    https://brew.sh/
                  3. Install python3
                    Please type the command.
                    $ brew install python3
                  4. Put a symbolic link
                    $ sudo ln -s /usr/local/bin/python3 /usr/local/bin/python
                  5. Start M5Burner on Terminal
                    $ /Applications/M5Burner.app/Contents/MacOS/electron-m5burner-v2-eletron
                  best of luck to you!
                  ajb2k3A W 2 Replies Last reply Reply Quote 3
                    ajb2k3 @yopita
                    @yopita said in M5Burner does not work in MacOX 12.3.:
                      https://brew.sh/
                    3. Install python3
                    Step 4 is not correct but I see it worked for you.
                    Open terminal and go to settings, you should be able to add /usr/local/bin/python3 to the environmental setting or find the environmental file and add it it there.
                    • W
                      waqast @yopita
                      @yopita
                      https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139#issuecomment-1014816668
                      It worked for me
                      System:
                      MacOS Monterey 12.3.1 (Macbook Pro 2019 Intel)
                      Device
                      M5Stack Core2
                      • Install the driver CH9102_VCP_MacOS_v1.7 > CH34xVCPDriver.pkg
                      • Run the app CH34xVCPDriver in Applicatoins
                      • GO TO Security on Settings and allow the app to run
                      • Start Terminal App.
                      • Install homebrew.
                        Please refer to the installation on the page : https://brew.sh/
                      • Install python3
                      • Put a symbolic link
                      • Start M5Burner on Terminal
                      • Select COM port wchusbmodem
                      W R 2 Replies Last reply Reply Quote 0
                      • W
                        westwoodhk @waqast
                        @waqast
                        I couldn't solve it.
                        When I input this command
                        it comes out this message
                        ln: /usr/local/bin/python: File exists
                        Do someone know how to solve this?
                          You need to set the path in BASH's environment setting (if bash is still used) google for setting Micropython Environmental Patch in OSX. I can't help because my OSX is several version behind and won't be updated until I can afford to by a new MAC.
                          • R
                            rickkaye @waqast
                            @waqast When I follow these instructions, wchusbmodem does not show up as an available port in M5Burner. I checked in /dev and it is not there. The only port that M5Burner offers to me is /dev/tty.Bluetooth-Incoming-Port. My hardware is 2017 iMac5k MacOS Monterey12.3.1, M5Stack Core. Can anyone help?
                            oyoujiO ajb2k3A 2 Replies Last reply Reply Quote 0
                            • oyoujiO
                              oyouji @rickkaye
                              @rickkaye Try to turn M5stack off, then plug it in! Do not turn it on by yourself.
                                ajb2k3 @rickkaye
                                @rickkaye Take a look in "Security and preferences" to see if the driver has been blocked.
                                • P
                                  plusulli
                                  I updated today to macOS Monterey V 12.3.1 and everything is fine with M5Burner MacOS x64 v3.0
                                    mashimolab
                                    hello,
                                    I could resolve the problem by changing the part of putting a symbokic link like below.
                                    sudo ln -s /opt/homebrew/bin/python3 /usr/local/bin/python
                                    The install path of python3 with homebrew is changed to /opt/homebrew/bin directory as the default in M1 mac.
                                    System:
                                    MacOS Monterey 12.3.1 (Macbook Pro 2021 M1 Pro Max)
                                    Device
                                    M5Stack Fire
                                    • Y
                                      yu_with_a_mission
                                      @yopita
                                      I tried you way and get another error,
                                      "File"/Applications/M5Burner.app/Contents/Resources/packages/tools/serial/tools/list_ports_osx.py", line 32, in <module>
                                      kIOMasterPortDefault = ctypes.c_void_p.in_dll(iokit, "kIOMasterPortDefault")
                                      Burn Failed
                                      How can I solve?
                                      System:
                                      MacOS Monterey 12.4
                                      Device:
                                      M5StickCPlus
                                        ajb2k3 @yu_with_a_mission
                                        @yu_with_a_mission said in M5Burner does not work in MacOX 12.3.:
                                        @yopita
                                        Burn Failed
                                        How can I solve?
                                        System:
                                        MacOS Monterey 12.4
                                        Device:
                                        M5StickCPlus
                                        There is an Issue Montery.
                                        Have you installed Xcode from the App Store?
                                        Have you instilled the latest Python 3 from the python site?
                                        Have you installed the drivers?
                                        Have you set the PATH variable correctly?
                                        Have you copied the M5Burner V3 to the Applications folder?
                                        Have you erased the controller first before writing the correct firmware?
