    Pulse sensor connection
    Core 2
    4.4k
    • D
      david-bethesda
      Can this pulse sensor https://www.amazon.com/Shuian-Consumption-Compatible-Raspberry-MAX30100/dp/B09NZPDWB2/ref=sr_1_8 be connected to the grove port on a Core 2?
      • A
        AgreeDK @david-bethesda
        @david-bethesda the short answer is yes ;-)
        You Will have to make you own wiring/cable , then if using Arduino programmering find a library supporting the sensor, upload example code and test it 😉
        • D
          david-bethesda @AgreeDK
          @agreedk Thanks.
            Yes you will need to make your own wiring harness but in UIFLow it should be directly compatible.
