<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pulse sensor connection]]></title><description><![CDATA[<p dir="auto">Can this pulse sensor <a href="https://www.amazon.com/Shuian-Consumption-Compatible-Raspberry-MAX30100/dp/B09NZPDWB2/ref=sr_1_8" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.com/Shuian-Consumption-Compatible-Raspberry-MAX30100/dp/B09NZPDWB2/ref=sr_1_8</a> be connected to the grove port on a Core 2?</p>
]]></description><link>https://community.m5stack.com/topic/4171/pulse-sensor-connection</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 18:22:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4171.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Apr 2022 15:29:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pulse sensor connection on Sun, 03 Apr 2022 06:11:36 GMT]]></title><description><![CDATA[<p dir="auto">Yes you will need to make your own wiring harness but in UIFLow it should be directly compatible.</p>
]]></description><link>https://community.m5stack.com/post/17074</link><guid isPermaLink="true">https://community.m5stack.com/post/17074</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 03 Apr 2022 06:11:36 GMT</pubDate></item><item><title><![CDATA[Reply to Pulse sensor connection on Fri, 01 Apr 2022 20:28:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/agreedk" aria-label="Profile: agreedk">@<bdi>agreedk</bdi></a>  Thanks.</p>
]]></description><link>https://community.m5stack.com/post/17069</link><guid isPermaLink="true">https://community.m5stack.com/post/17069</guid><dc:creator><![CDATA[david-bethesda]]></dc:creator><pubDate>Fri, 01 Apr 2022 20:28:36 GMT</pubDate></item><item><title><![CDATA[Reply to Pulse sensor connection on Fri, 01 Apr 2022 19:03:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david-bethesda" aria-label="Profile: david-bethesda">@<bdi>david-bethesda</bdi></a> the short answer is yes ;-)<br />
You Will have to make you own wiring/cable , then if using Arduino programmering find a library supporting the sensor, upload example code and test it 😉</p>
]]></description><link>https://community.m5stack.com/post/17068</link><guid isPermaLink="true">https://community.m5stack.com/post/17068</guid><dc:creator><![CDATA[AgreeDK]]></dc:creator><pubDate>Fri, 01 Apr 2022 19:03:14 GMT</pubDate></item></channel></rss>
