    M5Stack Gauges for Boats
    PROJECTS
    6.7k
    • H
      Hans-J.
      this is my first post in this forum. I am pretty new to this product and not very experienced in Arduino programing. So I need your help in order to finalize my project. I do need several gauges for my boat. So I decided to try the M5Stack which allows me to display 3 different gauges on one display by simply pressing one of the three buttons. As a start I used the example "TFT_Meter_linear". So far the functionality is given. However, I would like to rotate the scale and the pointer. The command "tft.setRotation()" doesn't do it. I would appreciate if someone could give me a hint on which values I have to manipulate in order to get the desired result. I have attached a picture of the current and the required display as well as the code
      Best regards
      0_1618302186104_Rudder.JPG image url)
       An example analogue meter using a ILI9341 TFT LCD screen
       Needs Font 2 (also Font 4 if using large scale label)
       Make sure all the display driver and pin comnenctions are correct by
       editting the User_Setup.h file in the TFT_eSPI library folder.
       ###### DON'T FORGET TO UPDATE THE User_Setup.h FILE IN THE LIBRARY ######
      Updated by Bodmer for variable meter size
      // Define meter size as 1 for M5.Lcd.rotation(0) or 1.3333 for M5.Lcd.rotation(1)
      #define M_SIZE 1.3333
      #include <M5Stack.h>
      #define ADC_Calibration_Value1 250.0 // For resistor measure 5 Volt and 180 Ohm equals 100% plus 1K resistor.
      #define ADCpin1 35  // Potentiometer is connected to GPIO 35 (Analog ADC1_CH7)
      // add a 1k Resistor from pin 35 to +5V and a Diode from GND to pin 35 (Cathode)
      // a 10µf cap from GND to pin 35 may reduce a noisy needle
      #define TFT_GREY 0x5AEB
      float ltx = 0;    // Saved x coord of bottom of needle
      uint16_t osx = M_SIZE*120, osy = M_SIZE*120; // Saved x & y coords
      uint32_t updateTime = 0;       // time for next update
      int old_analog =  -999; // Value last displayed
      int value[6] = {0, 0, 0, 0, 0, 0};
      int old_value[6] = { -1, -1, -1, -1, -1, -1};
      int d = 0;
      // variable for storing the potentiometer value
      int potValue = 0;
      void setup(void) {
        M5.Power.begin();
        // M5.Lcd.setRotation(1);
        // Serial.begin(57600); // For debug
        M5.Lcd.fillScreen(TFT_BLACK);
        analogMeter(); // Draw analogue meter
        updateTime = millis(); // Next update time
      // ReadADC is used to improve the linearity of the ESP32 ADC see: https://github.com/G6EJD/ESP32-ADC-Accuracy-Improvement-function
      double ReadADC(byte pin) {
        double reading = analogRead(pin); // Reference voltage is 3v3 so maximum reading is 3v3 = 4095 in range 0 to 4095
        if (reading < 1 || reading > 4095) return 0;
        // return -0.000000000009824 * pow(reading,3) + 0.000000016557283 * pow(reading,2) + 0.000854596860691 * reading + 0.065440348345433;
        return (-0.000000000000016 * pow(reading, 4) + 0.000000000118171 * pow(reading, 3) - 0.000000301211691 * pow(reading, 2) + 0.001109019271794 * reading + 0.034143524634089) * 1000;
      // Added an improved polynomial, use either, comment out as required
        potValue = ReadADC(ADCpin1) * ADC_Calibration_Value1 / 4096;
       Serial.print(ReadADC(ADCpin1));                   // print raw value
       Serial.print(" ");                                // tab
       Serial.println(potValue);                         // print final value
       delay(200); // to smoothen the pointer
        plotNeedle(potValue, 0);
      //  Draw the analogue meter on the screen
      void analogMeter()
        // Meter outline
        M5.Lcd.fillRect(0, 0, M_SIZE*239, M_SIZE*126, TFT_GREY);
        M5.Lcd.fillRect(5, 3, M_SIZE*230, M_SIZE*119, TFT_WHITE);
        M5.Lcd.setTextColor(TFT_BLACK);  // Text colour
        // Draw ticks every 5 degrees from -50 to +50 degrees (100 deg. FSD swing)
        for (int i = -50; i < 51; i += 5) {
          // Long scale tick length
          int tl = 15;
          // Coodinates of tick to draw
          float sx = cos((i - 90) * 0.0174532925);
          float sy = sin((i - 90) * 0.0174532925);
          uint16_t x0 = sx * (M_SIZE*100 + tl) + M_SIZE*120;
          uint16_t y0 = sy * (M_SIZE*100 + tl) + M_SIZE*140;
          uint16_t x1 = sx * M_SIZE*100 + M_SIZE*120;
          uint16_t y1 = sy * M_SIZE*100 + M_SIZE*140;
          // Coordinates of next tick for zone fill
          float sx2 = cos((i + 5 - 90) * 0.0174532925);
          float sy2 = sin((i + 5 - 90) * 0.0174532925);
          int x2 = sx2 * (M_SIZE*100 + tl) + M_SIZE*120;
          int y2 = sy2 * (M_SIZE*100 + tl) + M_SIZE*140;
          int x3 = sx2 * M_SIZE*100 + M_SIZE*120;
          int y3 = sy2 * M_SIZE*100 + M_SIZE*140;
          // Green zone limits
          if (i >= -50 && i < 0) {
            M5.Lcd.fillTriangle(x0, y0, x1, y1, x2, y2, TFT_GREEN);
            M5.Lcd.fillTriangle(x1, y1, x2, y2, x3, y3, TFT_GREEN);
          // Red zone limits
          if (i >= 0 && i <50) {
            M5.Lcd.fillTriangle(x0, y0, x1, y1, x2, y2, TFT_RED);
            M5.Lcd.fillTriangle(x1, y1, x2, y2, x3, y3, TFT_RED);
          // Short scale tick length
          if (i % 25 != 0) tl = 8;
          // Recalculate coords incase tick lenght changed
          // Draw tick
          M5.Lcd.drawLine(x0, y0, x1, y1, TFT_BLACK);
          // Check if labels should be drawn, with position tweaks
          if (i % 25 == 0) {
            // Calculate label positions
            x0 = sx * (M_SIZE*100 + tl + 10) + M_SIZE*120;
            y0 = sy * (M_SIZE*100 + tl + 10) + M_SIZE*140;
            switch (i / 25) {
              case -2: M5.Lcd.drawCentreString("40", x0, y0 - 12, 2); break;
              case -1: M5.Lcd.drawCentreString("20", x0, y0 - 9, 2); break;
              case 0: M5.Lcd.drawCentreString("CTR", x0, y0 - 7, 2); break;
              case 1: M5.Lcd.drawCentreString("20", x0, y0 - 9, 2); break;
              case 2: M5.Lcd.drawCentreString("40", x0, y0 - 12, 2); break;
          // Now draw the arc of the scale
          sx = cos((i + 5 - 90) * 0.0174532925);
          sy = sin((i + 5 - 90) * 0.0174532925);
          x0 = sx * M_SIZE*100 + M_SIZE*120;
          y0 = sy * M_SIZE*100 + M_SIZE*140;
          // Draw scale arc, don't draw the last part
          if (i < 50) M5.Lcd.drawLine(x0, y0, x1, y1, TFT_BLACK);
        M5.Lcd.drawString("Port", M_SIZE*(5 + 230 - 40), M_SIZE*(119 - 20), 2); // Label at bottom right
        M5.Lcd.drawString("STBD", M_SIZE*(5 + 60 - 40), M_SIZE*(119 - 20), 2); // Label at bottom left
        M5.Lcd.drawCentreString("Rudder", M_SIZE*120, M_SIZE*70, 4); // Comment out to avoid font 4
        M5.Lcd.drawRect(5, 3, M_SIZE*230, M_SIZE*119, TFT_BLACK); // Draw bezel line
        plotNeedle(0, 0); // Put meter needle at 0
      // Update needle position
      // This function is blocking while needle moves, time depends on ms_delay
      // 10ms minimises needle flicker if text is drawn within needle sweep area
      // Smaller values OK if text not in sweep area, zero for instant movement but
      // does not look realistic... (note: 100 increments for full scale deflection)
      void plotNeedle(int value, byte ms_delay)
        if (value < -10) value = -10; // Limit value to emulate needle end stops
        if (value > 110) value = 110;
        // Move the needle until new value reached
        while (!(value == old_analog)) {
          if (old_analog < value) old_analog++;
          else old_analog--;
          if (ms_delay == 0) old_analog = value; // Update immediately if delay is 0
          float sdeg = map(old_analog, -10, 110, -150, -30); // Map value to angle
          // Calcualte tip of needle coords
          float sx = cos(sdeg * 0.0174532925);
          float sy = sin(sdeg * 0.0174532925);
          // Calculate x delta of needle start (does not start at pivot point)
          float tx = tan((sdeg + 90) * 0.0174532925);
          // Erase old needle image
          M5.Lcd.drawLine(M_SIZE*(120 + 20 * ltx - 1), M_SIZE*(140 - 20), osx - 1, osy, TFT_WHITE);
          M5.Lcd.drawLine(M_SIZE*(120 + 20 * ltx), M_SIZE*(140 - 20), osx, osy, TFT_WHITE);
          M5.Lcd.drawLine(M_SIZE*(120 + 20 * ltx + 1), M_SIZE*(140 - 20), osx + 1, osy, TFT_WHITE);
          // Re-plot text under needle
          M5.Lcd.drawCentreString("Rudder", M_SIZE*120, M_SIZE*70, 4); // // Comment out to avoid font 4
          // Store new needle end coords for next erase
          ltx = tx;
          osx = M_SIZE*(sx * 98 + 120);
          osy = M_SIZE*(sy * 98 + 140);
          // Draw the needle in the new postion, magenta makes needle a bit bolder
          // draws 5 lines to thicken needle
          M5.Lcd.drawLine(M_SIZE*(120 + 20 * ltx - 1), M_SIZE*(140 - 20), osx - 1, osy, TFT_RED);
          M5.Lcd.drawLine(M_SIZE*(120 + 20 * ltx), M_SIZE*(140 - 20), osx, osy, TFT_MAGENTA);
          M5.Lcd.drawLine(M_SIZE*(120 + 20 * ltx + 1), M_SIZE*(140 - 20), osx + 1, osy, TFT_RED);
          // Slow needle down slightly as it approaches new postion
          if (abs(old_analog - value) < 10) ms_delay += ms_delay / 5;
          // Wait before next update
          delay(ms_delay);
      • A
        AndyT
        Sorry can't help your question. But would like to thank you for your code. Which i have adapted to display temperatures.
          macsbug
          Add the following to void loop ().
          M5.update();
          if(M5.BtnA.wasPressed()){M5.Lcd.setRotation(3);M5.Lcd.fillScreen(TFT_BLACK);analogMeter();}
          if(M5.BtnC.wasPressed()){M5.Lcd.setRotation(1);M5.Lcd.fillScreen(TFT_BLACK);analogMeter();}
