    M5StickC BUGC... why do we change charge current?!
    6.8k
      SarahC
      In BUGC.ino, there's an interesting line - "If add battery, need increase charge current".
      It's brief! I take it to mean - that if I use the little li-ion battery that comes with the BUGC, I need to include this line that changes the charging current of the M5StickC?
      I'm -guessing- that the battery in place also powers the M5StickC's internal battery charger?
      Why am I increasing it!? Shouldn't I be decreasing the charge current to it doesn't drain the robots power?
      What if I left it as whatever its default is?
      void setup()
      BugC.Init();
      M5.Lcd.setTextColor(TFT_GREEN);
      M5.Lcd.setRotation(1);
      M5.Lcd.drawCentreString("BUGC example", 120, 50, 4);
      // if add battery, need increase charge current
      M5.Axp.SetChargeCurrent(CURRENT_360MA);
        SarahC
        Ohhhhhh.....
        https://community.m5stack.com/topic/2625/m5stickcplus-doesn-t-program-correctly/3
        • m5stackM
          setting a fit charge current level would let the battery charge fast. if use the default charge current it would spend a long time to be full.
            SarahC @m5stack
            @m5stack Thank you!
