    M5Paper error message
    Cores
    8.5k
    • Z
      ZamZam
      When I upload an arduino program to M5Paper then there is the following message in the Arduino IDE:
      esptool.py v3.0-dev
      Serial port COM6
      Connecting....
      Chip is ESP32-D0WDQ6-V3 (revision 3)
      Crystal is 40MHz
      MAC: b8:f0:09:c6:29:10
      Uploading stub...
      Running stub...
      Stub running...
      Configuring flash size...
      Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
      Compressed 8192 bytes to 47...
      A fatal error occurred: Timed out waiting for packet content
      all my thanks for your help
      • ZontexZ
        Zontex
        Hello, are you having the same issue when you trying to burn the UIFlow firmware using the M5Burner? could you try and see if the M5Burner gives you any problems?
        • Z
          ZamZam
          Hello, i tried the "Factory test" firmware using the M5Burner and EasyLoader_M5Paper_Factory_Test but there is the same message.
          • P
            Powersoft @ZamZam
            @zamzam
            Do you have tried to slow down the upload speed. Had the same with other brands, after reducing the upload speed it works.
            Succes,
            Jan
            • Z
              ZamZam
              @Powersoft
              Hello, after contacting M5Stack support the problem is probably the flash chip, M5Stack is replacing my M5Paper.
              I had performed this upload test at slow speed but without improvement. Thanks for your help
