<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper error message]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">When I upload an arduino program to M5Paper then there is the following message in the Arduino IDE:</p>
<p dir="auto"><a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v3.0-dev<br />
Serial port COM6<br />
Connecting....<br />
Chip is ESP32-D0WDQ6-V3 (revision 3)<br />
Crystal is 40MHz<br />
MAC: b8:f0:09:c6:29:10<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB<br />
Compressed 8192 bytes to 47...<br />
A fatal error occurred: Timed out waiting for packet content<br />
A fatal error occurred: Timed out waiting for packet content</p>
<p dir="auto">all my thanks for your help</p>
]]></description><link>https://community.m5stack.com/topic/2605/m5paper-error-message</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 03:42:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2605.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Dec 2020 08:58:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper error message on Wed, 30 Dec 2020 21:32:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@Powersoft</a><br />
Hello, after contacting M5Stack support the problem is probably the flash chip, M5Stack is replacing my M5Paper.<br />
I had performed this upload test at slow speed but without improvement. Thanks for your help</p>
]]></description><link>https://community.m5stack.com/post/11451</link><guid isPermaLink="true">https://community.m5stack.com/post/11451</guid><dc:creator><![CDATA[ZamZam]]></dc:creator><pubDate>Wed, 30 Dec 2020 21:32:15 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper error message on Tue, 29 Dec 2020 15:07:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5528">@zamzam</a><br />
Do you have tried to slow down the upload speed. Had the same with other brands, after reducing the upload speed it works.<br />
Succes,<br />
Jan</p>
]]></description><link>https://community.m5stack.com/post/11419</link><guid isPermaLink="true">https://community.m5stack.com/post/11419</guid><dc:creator><![CDATA[Powersoft]]></dc:creator><pubDate>Tue, 29 Dec 2020 15:07:26 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper error message on Thu, 17 Dec 2020 15:41:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello, i tried the "Factory test" firmware using the M5Burner and EasyLoader_M5Paper_Factory_Test but there is the same message.</p>
]]></description><link>https://community.m5stack.com/post/11256</link><guid isPermaLink="true">https://community.m5stack.com/post/11256</guid><dc:creator><![CDATA[ZamZam]]></dc:creator><pubDate>Thu, 17 Dec 2020 15:41:31 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper error message on Thu, 17 Dec 2020 03:11:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello, are you having the same issue when you trying to burn the UIFlow firmware using the M5Burner? could you try and see if the M5Burner gives you any problems?</p>
]]></description><link>https://community.m5stack.com/post/11245</link><guid isPermaLink="true">https://community.m5stack.com/post/11245</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Thu, 17 Dec 2020 03:11:28 GMT</pubDate></item></channel></rss>
