    Problem speaker with M5stickC Plus
    5 Posts 2 Posters 11.2k Views
    • V Offline
      vgamlc
      I am using M5stickc plus at the moment I am very happy with them, but I have had a problem and I cannot find a solution.
      I am unable to make a beep sound and I am not listening because, I am attaching the code to see if they can help me.
      ERRROArduino:1.8.13 (Windows 10), Tarjeta:"M5Stick-C, Default, 1500000, None"
      C:\DISEÑOS\Arduino\sketch_nov25b\sketch_nov25b.ino: In function 'void loop()':
      sketch_nov25b:51:8: error: 'class M5StickCPlus' has no member named 'Speaker'
      exit status 1
      Thanks in advance.
      #include <M5StickCPlus.h>
      #define INTERVALO_LED 200
      #define INTERVALO_LECTURAS 1000
      uint8_t i = 12;// entre 7 y 12
      unsigned long tiempo;
      const int Led = 10;
      unsigned long Tiempo_Led_Encendido = 0;
      unsigned long Tiempo_entre_Lecturas = 0;
      Serial.begin(115200);
      // put your setup code here, to run once:
      pinMode (Led, OUTPUT);
      digitalWrite (Led, HIGH);
      M5.Lcd.setRotation(1); //Rotar LCD
      M5.Lcd.fillScreen(BLACK); //Vaciar pantalla y color
      M5.Lcd.setTextColor(WHITE); //Color Texto
      M5.Lcd.setTextSize(2); //Tamaño Texto
      M5.Axp.ScreenBreath(i);
      M5.update(); // need to call update()
      if (millis () > (Tiempo_entre_Lecturas + INTERVALO_LECTURAS))
      M5.Lcd.setCursor(0, 0);
      M5.Lcd.printf("V_Bateria: %.2fV\r\n", M5.Axp.GetBatVoltage());
      M5.Lcd.printf("I_Bateria: %.1fmA\r\n", M5.Axp.GetBatCurrent());
      M5.Lcd.printf("V_USB: %.3fV\r\n", M5.Axp.GetVBusVoltage());
      M5.Lcd.printf("I_USB: %.3fmA\r\n", M5.Axp.GetVBusCurrent());
      M5.Lcd.printf("Vin: %.3fV\r\n", M5.Axp.GetVinVoltage());
      M5.Lcd.printf("Iin: %.3fmA\r\n", M5.Axp.GetVinCurrent());
      M5.Lcd.printf("Bat power: %.3fmw\r\n", M5.Axp.GetBatPower());
      M5.Lcd.printf("Nivel: %u\r\n", M5.Axp.GetWarningLeve());
      Tiempo_entre_Lecturas = millis();
      if(M5.BtnA.wasPressed())
      digitalWrite (Led, LOW);
      Serial.println("Pulsado A");
      M5.Axp.ScreenBreath(i++);
      M5.Speaker.beep();//////////*****///////
      if (i > 12) i = 7;
      Tiempo_Led_Encendido = millis();
      if (!digitalRead(Led) & (millis () > (Tiempo_Led_Encendido + INTERVALO_LED)))
      // M5.Speaker.setBeep(900, 1000);
      • felmueF Online
        Hello @vgamlc
        I think the correct function to call is: M5.Beep.beep();.
        Cheers
        • V Offline
          vgamlc
          Thanks, you are a machine and fast.
          • V Offline
            vgamlc
            Another issue, I cannot change the volume on my M5stack Plus. Some help?
            • felmueF Online
              Hi @vgamlc
              I don't think you can change the volume of the beep. Although there is a setVolume() function the volume is only used in the PlayMusic() function, but not for the beep.
              Please also refer to the Speaker source code
