Emoji with M5 Fire
Hi
When I try to use emoji with UIFlow desktop and M5 Fire, it says "Error. No module named 'emoji' "
Details are
"File "<string>", line 3, in <module>
Import error: no module named 'square' "
I just updated the Fire to latest firmware so I don't understand what's wrong ?
(It does not work with UIFlow online either) -
I would not use the Desktop version of uiFlow for now, unless you have to. The web IDE uiFlow (https://flow.m5stack.com) is up to date at v1.6.2, but they are still working on updating the Desktop version (it has issues and bugs with v1.6.1).
I just tested the emoji on the Fire using the web IDE uiFlow v1.6.2 and it works. Make sure you are running firmware v1.6.2 on the Fire so it matches the web IDE and switch your device to Internet Mode in the device's Setup menu.
My M5burner does not have more than 1.5.2 for UIFlow-Fire firmware. Where can I find 1.6.2 ?
Thanx
I used the old M5burner, as the new one is for Windows10. Apparently it is ok with windows 7 too
