    Emoji with M5 Fire
    5 Posts 2 Posters 7.6k Views 1 Watching
      F3l1x
      Hi
      When I try to use emoji with UIFlow desktop and M5 Fire, it says "Error. No module named 'emoji' "
      Details are
      "File "<string>", line 3, in <module>
      Import error: no module named 'square' "
      I just updated the Fire to latest firmware so I don't understand what's wrong ?
      (It does not work with UIFlow online either)
      • world101W Offline
        world101 @F3l1x
        @f3l1x
        I would not use the Desktop version of uiFlow for now, unless you have to. The web IDE uiFlow (https://flow.m5stack.com) is up to date at v1.6.2, but they are still working on updating the Desktop version (it has issues and bugs with v1.6.1).
        I just tested the emoji on the Fire using the web IDE uiFlow v1.6.2 and it works. Make sure you are running firmware v1.6.2 on the Fire so it matches the web IDE and switch your device to Internet Mode in the device's Setup menu.
          F3l1x
          My M5burner does not have more than 1.5.2 for UIFlow-Fire firmware. Where can I find 1.6.2 ?
          • world101W Offline
            world101
            https://m5stack.com/pages/download
            Latest is M5burner v2.1.5
              F3l1x
              Thanx
              I used the old M5burner, as the new one is for Windows10. Apparently it is ok with windows 7 too
