Same issue here, with the M5Stack Core 1. Just installed all the packages / libraries following the M5Stack instructions. #include <M5Stack.h> void setup() { // put your setup code here, to run once: M5.begin(); M5.lcd.print("Hello World!"); } void loop() { // put your main code here, to run repeatedly: } Output: c:\Arduino\libraries\M5Stack\src\utility\pngle.c:31:10: fatal error: rom/miniz.h: No such file or directory 31 | #include <rom/miniz.h> | ^~~~~~~~~~~~~ compilation terminated. exit status 1 Compilation error: exit status 1
