I would love to see Modbus TCP support in UIFlow.
Posts made by rob.driver1970
    UIFlow Modbus TCP support.posted in Features Wish List
    Are there any good tutorials out there for the atom s3 light?posted in General
Are there any good tutorials out there for the atom s3 light? I haven't had any luck getting it to run anything, not even a simple LED color change. I would love to be able to just push sensor values over MQTT but I can't even do the simplest of task. I set up Core 2s with UIFlow 1.0 with no problems but version 2.0 is a different animal. If anyone knows of some example code out there it would be much appreciated. Wanting to eventually read an RFID card and push the number across MQTT.
    How do you get the API key for an Atom S3 lite?posted in Atom
I click the configure button in the burner but the API key is not listed. This is my first time with the atom but Used the Core 2 and it always was there. Looked at the quick setup guide and the example picture that it shows doesn't have it listed either. Am I just stupid or blind?
    M5 Stack Core2 UI flow program stopped connecting to the WI-FI in the program.posted in Bug Report
Re: I can't connect the M5 Stack Core2 to WiFi in my program.
It was working then one day I booted it up and it just stopped working. I saw the reply to a previous post about this and used the example with no results. I have tried to reflash but it did not help. It connects outside the program fine. it is a hidden network but like I said it was working before.
Thanks
Rob
    RE: Mqtt will not publish.posted in UIFlow
It just didn't like the Mosquitto broker in Home Assistant I installed EMQX Broker and it works like a charm.
Just a test setup at the moment. I can subscribe and get the topic message. When I press the buttons, the test display shows the buttons were pressed but the message does not post to the broker.
I have an M5Stack core 2 that I'm trying to get to publish to a Mosquito broker installed in Home Assistant. I can subscribe fine but I just can't get it to publish. Is anyone else having issues with this? Could it be the firmware revision? I can send topics through Node Red and receive them fine but no matter what I try I can't get it to publish.
