@felmue said in Lora868 Module and Cardkb:
Thank you for your reply. Will try the Ext Port for Core 2 module as that looks like it might work. Thanks again.
Hi new here. Trying to help my son with his M5Stack project. He is trying to use the Lora868 Module with the CardKB but there appears to be a conflict between the two, possible both trying use Pin33. He is using the Core2 and UIFlow. When both are added to a UIFlow project it gives the following error:
Invalid Version
File"<string>",line23,in <module>
File"modules/.lora433.py",line 100, in config Lora433_ERROR:Invalid version.
Any ideas would be greatly appreciated as he is set on using both the CardKB and the Lora686 module together. Thank you.
