T
@kuriko Hola¡¡ puedes indicarme como lo has conseguido, ayer me pude logear sin problema, pero hoy no hay forma, puedo entrar en https://uiflow2.m5stack.com/ pero imposible en m5burner. Gracias¡¡
K
@neus-morla have you tried link it directly to your Fire? it may be a PbHub config problem
R
Hi@neus-morla , If you have the device as it came from the factory, try this:
Download M5burner. Log in. In core, look for UIFlow_Fire; this will flash the updated firmware (this might be the problem).
