I made a simple audio-to-MIDI trigger using the MIDI Unit. It works surprisingly well!
Posts made by michael.koppelman
MIDI Triggerposted in PROJECTS
RE: No files ever work with the Speakerposted in UIFlow
This is because UIFlow2.0 sucks with the M5Go. Almost no hardware works. I would abandon all the silly BS and go right to PlatformIO if you want to avoid pulling your hair out.
This ecosystem is so convoluted. I thought I might buy these for presents for kids. No way. Your average parent could not make this shit work ever.
RE: M5Unified Documentationposted in PROJECTS
How do you deprecate an API and not have documentation for the new API?
Here's the docs for the button class:
https://docs.m5stack.com/en/arduino/m5unified/touch_class
Where are the docs for the Display class? No one knows.
Where is the comprehensive, definitive documentation for this library? NOWHERE.
It has been 2 years.
I've loaded a small, mono, 16-bit, 44.1kHz audio file into flash in UFlow 2.0. It plays fine within UFlow. No matter what I do, I get an ENOENT error trying to read the file.
Traceback (most recent call last): File "<stdin>", line 26, in <module> File "<stdin>", line 18, in loop OSError: [Errno 2] ENOENTa snippet of the code from the Python side of things:
def setup(): global rgb M5.begin() Widgets.setRotation(1) Widgets.fillScreen(0x222222) rgb = RGB() Speaker.begin() Speaker.setVolumePercentage(0.5) def loop(): global rgb M5.update() Speaker.playWavFile('/flash/res/audio/test1.wav') if Speaker.isPlaying(): rgb.fill_color(0xffffff) time.sleep(2)No code I've downloaded from other people works either! I can play tones out of the speaker, I can read images out of flash. I cannot read audio files out of flash.
