@kawabatapaper Hi there! Can you please provide the program? and also every time the error occurs in about 9 hours?
Posts made by M5Stack_AG
    RE: Error : can't create threadposted in FAQS
    RE: V-Training says "You must log in before uploading data"posted in General
@lagd sorry they will fix it in one week
    RE: I want M5StickC can use BLE via Uiflow/microPythonposted in Features Wish List
@mrsteveman1 Hi there! I will forward your request to our technical support, thank you for letting us know!
    RE: UHF-RFID-UNIT-JRD-4035 effective distanceposted in PRODUCTS
@paopao Hi! If using UIFlow, then this is it, if it‘s Arduino. Serial port sending commands
or use API, then CH_index = 1
https://github.com/m5stack/M5Stack/blob/master/examples/Unit/UHF_RFID_JRD4035/RFID_command.cpp
    RE: GPS - incorrect readingsposted in PRODUCTS
@dsrc12 Hi! This must be outdoors in wide-open areas, cold start time takes about 3 / 4 minutes
    RE: M5Stack core2 communicate with ROSposted in PRODUCTS
@lishengkkk Hi there, please check if the baud rate of both sides match (you can also try to change the baud rate, such as the common 115200). If it's a UART via separate wiring. Please make sure TX RX is connected correctly.
@k_hara Hi, We are fixing it! sorry for the inconvenience
@mpierce Hi, We are fixing it! sorry for the inconvenience
@lagd Hi, We are fixing it! sorry for the inconvenience
    RE: Speaker.Volume on Core2posted in Features Wish List
@hoodlem Hi! Thanks for the feedback! this is already on our lists! stay tuned for more
    RE: core2 MBUS PIN for speaker outputposted in Features Wish List
@hoodlem Hi there! Core2 uses I2S digital power amplifier chip, which is different from Core1
    RE: M5 AC Socket and M5 Light Socketposted in Features Wish List
@glennswest Hi there, thanks for your feedback! we will be sure to let our innovation team know!
    RE: Addressable I2C Switchposted in Features Wish List
@glennswest Hi there! please have a look at https://docs.m5stack.com/en/unit/extio2
this supports software configuration of I2C address -
    RE: M5-Stamp-Pico with I-PEX external antenna portposted in Features Wish List
@chrismal Hi Good day! We appreciate your feedback!No IPEX version is available
    RE: Use Atom RS485 as a data snifferposted in PRODUCTS
Hi there We appreciate your feedback! but so far there is no demo provided
    RE: Native support of the Edge Impulse for the M5Stack UnitV2 development boardposted in SOFTWARE
Hi there we appreciate your feedback! we will share this with our team:) but no plan of it yet
    RE: [PRODUCT] M5KNX Coupler Unit / Moduleposted in Features Wish List
    RE: vlearning login porblemsposted in General
Hi there We appreciate your feedback! can u check one more time now
