In more than one project I encounter the same problem: Interrupt wdt timeout on CPU0.
Sometimes within an hour, sometimes after 20 hours.
By searching the internet about this issue I came across a new esp-def framework.
This problem would have solved this in version 3.3.4 of esp-idf.
I am using PlatformIO with M5Stack and esp32doit-devkit-v1.
Is it possible to benefit from esp-idf or is there no relation.
H
Latest posts made by hgmvanbeek
Core 0 panic'ed (Interrupt wdt timeout on CPU0)
M5StickC-Plus Odd Display behavior
With M5Burner I Burned UIFLOW for M5StickC-Plus.
This resulted in:
I burned the Dino-demo with result:
I wrote a testprogram for text:
/*- DisplayTest.ino
- M5StickCPlus
- Display: ST7789v2 135x240
#include <M5StickCPlus.h>
M5.Axp.ScreenBreath(10);
M5.Lcd.begin();
M5.Lcd.fillScreen(BLACK);
M5.Lcd.setRotation(3);
M5.Lcd.setTextSize(4);
M5.Lcd.setTextColor(WHITE);
M5.Lcd.setCursor(20, 60);
M5.Lcd.print("27 28 29");
}void loop() {
}As a result I got this:
What is going on ??
