    Help!
    ESPHome
    1.0k
    • C
      cr3al
      Hello everyone,
      I have an M5Stick Plus2 (ESP32-S3) and I tried to flash the Bruce firmware using an Android phone with OTG. I use esp32 flasher app.
      Here is exactly what I did:
      Device: M5Stick Plus2
      Flashing from Android phone (OTG)
      Bootloader: AUTO
      Baud rate: 115200
      Compression: OFF
      Erase Flash: ON
      Used a Plus2 / ESP32-S3 compatible .bin file
      Flash process completed successfully (no error)
      After flashing:
      The green LED turns on
      The device is detected over USB
      But the screen stays completely black
      Power button works (LED reacts), but no display at all
      I also tried:
      Erase Flash multiple times
      Power reset (long press)
      Flashing again with the same settings
      Result is always the same: LED on, no screen output.
      From what I understand, the device is not hard-bricked, but possibly:
      Wrong/incomplete display initialization
      Missing stock firmware / partitions
      Firmware incompatibility with Plus2 screen driver
      My questions:
      Is this a known issue when flashing Bruce on M5Stick Plus2?
      Is reflashing the official stock firmware (via M5Burner on PC) the correct recovery method?
      Is there any way to fully recover the display without a PC, or is a PC required?
      After restoring stock firmware, can Bruce be safely reinstalled again?
      Any help or confirmation would be really appreciated.
      Thanks in advance!
      robskiR 1 Reply Last reply Reply Quote 0
      • robskiR
        robski @cr3al
        @cr3al no experience with flashing via phone, in general I had no issues with bruce/nemo etc, and M5StickC devices, just be sure its correct firmware for StickC StickC+ StickC+2
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ, M5Tab, M5CardputerAdv
