    Glass2
    Units
    2.7k
    • T
      tonyd
      Hi All
      I've got a Glass2 unit attached to a Atom Lite via a grove cable. I can't find any documentation around how to access it. In UIFLOW2, I've found a init block that gives this code
      def setup():
        global i2c0, glass2_0
        M5.begin()
        i2c0 = I2C(0, scl=Pin(32), sda=Pin(26), freq=100000)
        glass2_0 = M5.addDisplay(i2c0, 0x3c, {"unit_glass2":True})
      But I can't se how to access the glass to write text. Has anyone managed to do this?
      Thanks
      Tony
      robskiR 1 Reply Last reply Reply Quote 0
      • robskiR
        robski @tonyd
        https://docs.m5stack.com/en/unit/Glass Unit?id=protocol
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ, M5Tab, M5CardputerAdv
        T 1 Reply Last reply Reply Quote 0
        • T
          tonyd @robski
          @robski Thanks
          I was looking on the GLASS2 page and there are no UIFLOW examples on there. I have come to the conclusion that GLASS2 is not fully implemented in UIFLOW2 as when I went back to UIFLOW1 there is a whole load of methods exposed on there. I may just have to learn a bit more about I2C and code via the Arduino IDE
          Tony
