M5Core2 play wav audio failed by use M5.Speaker class
Hardware: M5Core2
Platform:ArduinoQ:
I have prepared a wave format file in the TF card and want to play it through the M5.Speaker class, but the audio cannot be played normally after configuring the Speaker// code void playSpeak(File* file) { auto config = M5.Speaker.config(); config.pin_data_out = 2; config.pin_ws = 0; config.sample_rate = 16000; config.dma_buf_len = 1024; config.dma_buf_count = 2; // config.buzzer = true; config.i2s_port = I2S_NUM_0; M5.Speaker.config(config); M5.Speaker.begin(); // M5.Speaker.tone(661, 1000); M5.Speaker.setAllChannelVolume(255); M5.Speaker.setVolume(64); M5.Speaker.setChannelVolume(0, 255); // bool status = M5.Speaker.tone(2000, 1000); uint8_t* dataBuf = (uint8_t*)malloc(file->size()); file->read(dataBuf, file->size()); Serial.printf("File Content: %d", file->size()); bool status = M5.Speaker.playWav(dataBuf, file->size(), 1, 1, true); if (!status) { Serial.println("Failed to play"); } free(dataBuf); file->close(); M5.Speaker.end(); i2s_driver_uninstall(I2S_NUM_0); }
I have opened the source official test code in the Speaker class to print the WAV file information. The port print content is as follows:
Speech Start File Content: 957804[ 14851][D][Speaker_Class.cpp:772] playWav(): [wav] RIFF : RIFF [ 14851][D][Speaker_Class.cpp:773] playWav(): [wav] chunk_size : 957796 [ 14855][D][Speaker_Class.cpp:774] playWav(): [wav] WAVEfmt : WAVEfmt [ 14862][D][Speaker_Class.cpp:775] playWav(): [wav] fmt_chunk_size : 16 [ 14868][D][Speaker_Class.cpp:776] playWav(): [wav] audiofmt : 1 [ 14874][D][Speaker_Class.cpp:777] playWav(): [wav] channel : 1 [ 14880][D][Speaker_Class.cpp:778] playWav(): [wav] sample_rate : 16000 [ 14887][D][Speaker_Class.cpp:779] playWav(): [wav] byte_per_sec : 32000 [ 14894][D][Speaker_Class.cpp:780] playWav(): [wav] block_size : 2 [ 14900][D][Speaker_Class.cpp:781] playWav(): [wav] bit_per_sample : 16 Speech end
To solve this problem, I tried the following:
- Test whether the hardware power amplifier is available. I tested the power amplifier through the official tone function to make sound normally.
- Read and learn I2S-related knowledge, and understand the basic principles
- Check the ESP32 I2S related instructions on the Internet
But I didn't solve my problem, hope anyone can help me to find out where is the problem. Thank you so much!
