    Bouncing Ball project Confusion.
    UiFlow 2.0
    4.6k
    • ajb2k3A
      ajb2k3
      I'm trying to create a GUI example which bounces a ball around the screen for my book but when the code is run I get the error message:
      === import os, sys, io
      === import M5
      === from M5 import *
      === import time
      === circle0 = None
      === SCREEN_WIDTH = None
      === SCREEN_HEIGHT = None
      === Direction_x = None
      === Direction_y = None
      === Ball_Radius = None
      === def setup():
      ===   global circle0, SCREEN_WIDTH, SCREEN_HEIGHT, Direction_x, Direction_y, Ball_Radius
      ===   M5.begin()
      ===   Widgets.fillScreen(0x222222)
      ===   circle0 = Widgets.Circle(52, 91, 15, 0xffffff, 0xffffff)
      ===   SCREEN_WIDTH = int(320)
      ===   SCREEN_HEIGHT = int(240)
      ===   Direction_x = int(1)
      ===   Direction_y = int(1)
      ===   Ball_Radius = int(10)
      ===   circle0.setRadius(r=(int(Ball_Radius)))
      ===   circle0.setColor(color=0x6600cc, fill_c=0x6600cc)
      ===   circle0.setCursor(x=0, y=0)
      ===   circle0.setCursor(x=(SCREEN_WIDTH / 2), y=(SCREEN_HEIGHT / 2))
      === def loop():
      ===   circle0.setCursor(x=(int(Direction_x)), y=(int(Direction_y)))
      ===   if (int(Direction_x)) + (int(Ball_Radius)) >= (int(SCREEN_WIDTH)) or (int(Direction_x)) + (int(Ball_Radius)) <= (int(SCREEN_WIDTH)):
      ===     Direction_x = Direction_x - Direction_x
      ===   if Direction_y + Ball_Radius >= SCREEN_HEIGHT or Direction_y + Ball_Radius <= Direction_y:
      ===     Direction_y = Direction_y - Direction_y
      ===   time.sleep(1)
      === if __name__ == '__main__':
      ===   try:
      ===     setup()
      ===     while True:
      ===       loop()
      ===   except (Exception, KeyboardInterrupt) as e:
      ===     try:
      ===       from utility import print_error_msg
      ===       print_error_msg(e)
      ===     except ImportError:
      ===       print("please update to latest firmware")
        File "<stdin>", line 35, in <module>
        File "<stdin>", line 24, in setup
      TypeError: can't convert float to int
      The UIflow code is as follows
      But I keep getting the error both not converting float to int on line 35?
      • M
        mtylerjr
        @ajb2k3 Try putting int() in python, or "convert to int" in uiflow, around each "SCREEN_xxxxx / 2"
        So that it ends up
        circle0.setCursor(x=(int(SCREEN_WIDTH / 2)), y=(int(SCREEN_HEIGHT / 2)))
        • ajb2k3A
          ajb2k3
          Thanks, but getting same error message and I went and put convert to int on everything.
          Seams like its actually ignoring the convert to int.
          • M
            mtylerjr
            Sometime when I get unhelpful error messages like that in python, I take out the try/except around the call to the function and that often results in more helpful (uncaught/unhandled) error messages?
            Id also assign 0 to all those variables instead of None - but thats because I hate python and dont like it choosing its own types.
            Sorry, not much help.
            • ajb2k3A
              ajb2k3 @mtylerjr
              @mtylerjr said in Bouncing Ball project Confusion.:
              If you look as the block code you can see they are all defined, its just they way that MP/UIFlow implements variables.
              • M
                mtylerjr
                Did you try take the try/except out?
                If so, did the traceback give more helpful info?
                edit: I guess that's not do-able from uiflow. hmm
                Maybe circle.radius circle.x and circle.y are floats? still, I would expect different behavior.
                • ajb2k3A
                  ajb2k3
                  I did and it didn’t work. The problem is that missed a convert to int on one line. I fixed it but the circle doesn’t move because numberz iz hardz
                  • lbuqueL
                    lbuque
