Bouncing Ball project Confusion.
I'm trying to create a GUI example which bounces a ball around the screen for my book but when the code is run I get the error message:
=== import os, sys, io === import M5 === from M5 import * === import time === circle0 = None === SCREEN_WIDTH = None === SCREEN_HEIGHT = None === Direction_x = None === Direction_y = None === Ball_Radius = None === def setup(): === global circle0, SCREEN_WIDTH, SCREEN_HEIGHT, Direction_x, Direction_y, Ball_Radius === M5.begin() === Widgets.fillScreen(0x222222) === circle0 = Widgets.Circle(52, 91, 15, 0xffffff, 0xffffff) === SCREEN_WIDTH = int(320) === SCREEN_HEIGHT = int(240) === Direction_x = int(1) === Direction_y = int(1) === Ball_Radius = int(10) === circle0.setRadius(r=(int(Ball_Radius))) === circle0.setColor(color=0x6600cc, fill_c=0x6600cc) === circle0.setCursor(x=0, y=0) === circle0.setCursor(x=(SCREEN_WIDTH / 2), y=(SCREEN_HEIGHT / 2)) === def loop(): === global circle0, SCREEN_WIDTH, SCREEN_HEIGHT, Direction_x, Direction_y, Ball_Radius === circle0.setCursor(x=(int(Direction_x)), y=(int(Direction_y))) === if (int(Direction_x)) + (int(Ball_Radius)) >= (int(SCREEN_WIDTH)) or (int(Direction_x)) + (int(Ball_Radius)) <= (int(SCREEN_WIDTH)): === Direction_x = Direction_x - Direction_x === if Direction_y + Ball_Radius >= SCREEN_HEIGHT or Direction_y + Ball_Radius <= Direction_y: === Direction_y = Direction_y - Direction_y === time.sleep(1) === if __name__ == '__main__': === try: === setup() === while True: === loop() === except (Exception, KeyboardInterrupt) as e: === try: === from utility import print_error_msg === print_error_msg(e) === except ImportError: === print("please update to latest firmware") === === === Traceback (most recent call last): File "<stdin>", line 35, in <module> File "<stdin>", line 24, in setup TypeError: can't convert float to int
The UIflow code is as follows
But I keep getting the error both not converting float to int on line 35?
@ajb2k3 Try putting int() in python, or "convert to int" in uiflow, around each "SCREEN_xxxxx / 2"
So that it ends up
circle0.setCursor(x=(int(SCREEN_WIDTH / 2)), y=(int(SCREEN_HEIGHT / 2)))
Thanks, but getting same error message and I went and put convert to int on everything.
Seams like its actually ignoring the convert to int. -
Sometime when I get unhelpful error messages like that in python, I take out the try/except around the call to the function and that often results in more helpful (uncaught/unhandled) error messages?
Id also assign 0 to all those variables instead of None - but thats because I hate python and dont like it choosing its own types.
Sorry, not much help.
@mtylerjr said in Bouncing Ball project Confusion.:
If you look as the block code you can see they are all defined, its just they way that MP/UIFlow implements variables.
Did you try take the try/except out?
If so, did the traceback give more helpful info?
edit: I guess that's not do-able from uiflow. hmm
Maybe circle.radius circle.x and circle.y are floats? still, I would expect different behavior.
I did and it didn’t work. The problem is that missed a convert to int on one line. I fixed it but the circle doesn’t move because numberz iz hardz
