    M5Stick FRIED
    M5 Stick/StickC
    4
    10
    10.3k
    • C
      cepics
      Hi all, here my fried M5Stick can I save it?
      • lukasmaximusL
        lukasmaximus
        How is it fried, what happened? nothing appears on the screen? does the LED light up? have you tried re-flashing it.
        • ajb2k3A
          ajb2k3
          how does it burn?
          does it let out smoke?
          • C
            cepics
            Yes smoke from this regulator (I think) I was playing with lidar lite v3 connected via I2C 0_1546644917751_ACD5CE19-5B49-4CAA-BAA1-9162251ECD67.jpeg
            • ajb2k3A
              ajb2k3
              You may be able to replace it if you have the tools but there is a chance that something else broke.
              You also need to look into why it burnt.
              C 1 Reply Last reply Reply Quote 0
              • C
                cepics @ajb2k3
                @ajb2k3 what this component is?
                I was connecting lidar lite v3 PWM to M5Stick grove connector where the Stick start being hot...
                • ajb2k3A
                  ajb2k3 @cepics
                  @cepics I don't know as Mine has only just been dispatched. I think the Lidr may need to be powered separately to stick.
                  • ajb2k3A
                    ajb2k3
                    @lukasmaximus Am I reading the schematics correct?
                    It looks like a NPN8050 transistor connected to the microphone.
                    m5-docsM 1 Reply Last reply Reply Quote 0
                    • m5-docsM
                      m5-docs @ajb2k3
                      @ajb2k3 Looks like Voltage regulator chip - 5v to 3.3v
                      Triode is smaller than it.
                      M5Stack documentation URL
                      https://docs.m5stack.com
                      • ajb2k3A
                        ajb2k3 @m5-docs
                        @watson said in M5Stick FRIED:
                        Thanks @watson
